Results 1 to 11 of 11
Thread: Steering rack rattle
    PietroChocko is offline Nurses do it better.
    Was a VN Executive 5.0, but now a Ford Laser Auto.
    Sep 2009
    Default Steering rack rattle
    Hi there, I searched already to see if there was a thread about this but didn't find anything that answered my question.
    Anyways I'm currently selling my VN, and had a guy come out to look at it to buy it. He was driving it and went to do a U-Turn and the steering shuddered. He then said how that sounds really bad, and none of his cars do that. It happened again when he turned somewhat abruptly, and said the same thing again.
    The thing is, we've had that steering rack replaced twice in the last 5 years, and since we've had the car (according to my dad) it has always had some sort of shudder when you turn the steering too quickly. It's been properly maintained and hasn't slid into a kerb or anything like that.
    So is it a bad thing? Or is it just a standard fault, like I thought it was? Thanks for reading.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    How is your Struts and Shocks?
    I dont know if that can cause a Vibration tho..
    Check your Power Steering Fluid to, it might be low..Or need a change :S
    If i think of anything that can help, i'll post back.
    Good luck!
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Sounds like the power steering pump to me - as said above ^^ could be a little low on oil. Does it leak at all?
    and 3 Dangerous non ABS VN's
    1992 VP vacationer
    Nov 2009
    I get that too. real bad! if some one watches the car from the outside while I turn they see the front wheels bounce as I turn.
    I changed my shocks and it still does it so I am about to rebuild the whole front end from scratch. last thing on my list to get before i do so is a new rack as its stuffed too.
    Sep 2009
    Thanks for the posts guys, it's appreciated.
    I put in a new front suspension and wheel bearings last October, so it isn't the suspension. I honestly haven't checked the power steering fluid, so I'll do that once I get home from Uni today. It definitely doesn't leak, but it used to, hence the replacement of it.
    Dec 2009
    Quote Originally Posted by PietroChocko View Post
    When I had my VN it sometimes had a mild shudder. I just flushed the system with new fluid and then added some Nulon conditioner. Same thing with my VY now. It had a bad shudder I replaced the fluid and used Nulon and it virtually went away for a while and is just coming back after 12 months. If that doesn't fix it and the rack is good it could be the pump and Holmart have or had reconditioned ones really cheap no change over needed.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It's more of a vibration than a shudder though isn't it? My partners VN does it too, I have checked or replaced just about everything it could be but it still does it, only around left hand corners though. We did tie rod ends, rack ends, wheel bearings, we even swapped wheels. I don't think the radius rod bushes have been done yet though.
    Visit my Facebook page
    1992 VP vacationer
    Nov 2009
    my strut tops knock and flex in and out when pushing on the bonnet. i have a set of nolathane adjustable ones here ready to go in.
    Try looking at those.
    Sep 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    It's a shudder, but that is a subjective term I guess.
    I checked the level and it is about 1/2 a centimetre down from the Full:Cold marking. Does it require a top-up? I'd have no bloody clue how much to put into it.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    To describe what the missus VN does, the wheel shakes violently, like you have an out of balance front wheel, but it only does it going around left hand corners.
    The PS fluid is fine, 1/2cm down is nothing to be concerned about, but the correct amount to put in would be to top it up to the Full:Cold line when it is cold.
    VP V8 Auto
    Mar 2010
    Hey, I have a similar problem with my VP. When braking I get a strong shudder through the steering wheel. The problem is more prominent when lightly braking down hill above 80km/h. I have changed the front disks + pads and the sway bar linkage rubbers to nolathane bushes due to them being worn. I also have shanged the strut tops to adjustable nolathanes. The only thing left I could think it could be is the wheels themselves.
    Has anyone got any idea of anything else that may be faulty???
  1. [VIC] WTB VN steering rack
    By Shortstuff in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2009, 08:32 PM
  2. VQ steering rack into VK
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-07-2009, 09:59 AM
  3. steering rack
    By vr-man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2009, 03:50 PM
  4. steering rack
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2008, 02:35 AM
  5. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
