Results 1 to 6 of 6
Thread: vp v6 intermitant starting problem
    VZ cluby LS2 m6
    Jul 2009
    central QLD
    Default vp v6 intermitant starting problem
    Hi I tryed the search function be could not find anything the same.
    my vp v6 will sometime just wind and wind and not fire, wait a bit then press remote and sometime it will go sometimes not.
    It does this hot or cold, when going it runs fine, can hear fuel pump at all times.
    Any ideas, crank sensor???
    thanks in advance.
    VZ cluby LS2 m6
    Jul 2009
    central QLD
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    could be stator motor , alarm system. earths
    wat u mean by wind?? rotate?
    COMMODORE VP
    Dec 2008
    VZ cluby LS2 m6
    Jul 2009
    central QLD
    hey commy vp thanks for replys mate.. yeah it just turns over and over and will not fire... but then it could go a week and start first time every time...starter motor spins very strong..when you say key do you mean remote? have put a new battery in remote...it's so strange how intermitant this problem happens.
    I was unware of being able to check codes until reading about them on here...i will check next time it happens.
    cheers
    vp calais
    May 2006
    adelaide
    i have something similar, i got a vp calais with the zadi security system in it, it unlocks fine, all lights on dash come on, but sometimes the engine light wont n the fuel pump wont run. the car will fire for a second then die, then will just crank over n not fire. ive tried a heap of things but sometimes just switching the ignition on and off a few times will make the engine light come on and it will start and run fine.
    ive also noticed my engine light will flicker on and off like it has a loose connection or something
  1. intermitant cutout please help
    By vs-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 06:52 PM
  2. intermitant Acc issues
    By -=ApheX=- in forum Electrical Wiring / Questions
    Last Post: 12-02-2009, 10:22 AM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. intermitant transmission problem
    By achimw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2006, 08:37 AM
  5. intermitant engin fail
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2004, 01:47 PM
