so i have a vp commodore , factory 5 speed manual , has an lsd in it , but the diffs had it , loud as anything pretty sure its gonna go soon , so wondering , whats a good diff to put in ? wanted an lsd and have heard some falcon diffs fit ? so throw us your ideas for a good diff , that isn't fgonna cost to much , poor student :P
cheers guys
World Famous In New Zealand Since 18 years ago...
Ford Falcon up to Au I think and Fairlane 6 cyl run the same diff centre as Commodore 6 cyl. Gearing is different. These are all Borg Warner 25 spline axles. I just listed an LSD centre on ebay this morning for $99.
Fairly sure they are 28spline NPreston..... ?
OP, you can usually get VN-P open centre complete rear axles for under $100 over here, that'd be the way to go if you're on a budget. A disc to disc LSD will be a bit of a gamble but should also be fairly cheap
Sam
WTB: mulberry VN interior parts
From what i have heard a diff form a automatic Nissan Pintara will bolt straight in and there 4.11 ratio
I think you will find 6 cyl diff is 25 spline and V8 is 28 spline.
Live axle? if so, vl-vs liveaxles will bolt in..... a vl diff would probably be abit out of your price range but, people seem to ask a shitload for vlt and vl8 diffs (na 6 isnt worth it because its a 25 spline)
Diffs from pintaras, skylines, falcons etc will not "bolt straight in" because of different mounting points but the internals of the diff are the same...
Only 25 spline diffs out of the falcons where the old one's (finished in xf) then from ea became 28spline.....
Pretty sure, i wrote it somewhere here ages ago but cant remember atm to be honest, so go searching if you can be bothered lol
cheers guys , found a vn diff for 50 bucks so i think that will do untill i can save some money lol
Isn't this only pre-VN? Like VK and VL? Check this out - diff, all you need to know
Correct. Pre-VN. There is a 28 spline minispool in a VN 6cyl singo' diff in my VN
Sam
