Results 1 to 8 of 8
Thread: vn timing chain
    vn 3.8 exec
    Aug 2005
    Default vn timing chain
    im going to do the timing chain on the vn 3.8 v6 iis ther any tricks involved
    thanks
    Madhouse_Dave's Avatar
    Madhouse_Dave is offline Crazy but Happy
    Vt Berlina Sedan & VT Excutive Wagon
    May 2005
    Cool
    Hi
    The thing many have told Me is to do it correct the first go..
    take your time and make sure you don't miss anything.
    Check the oil pump while your in there its not common but
    you may come across one the is noisy.
    I know this one for sure because My Vn has a noisy rattley
    timing chain and the oil pump is going also..
    and last but not least change any gaskets you come across.
    Becarefull with the radiator and also check your hoses when you remove them.
    And last but not least good luck.. Let us know how it went and any snags\ troubles you come up against.
    I've Got Papers To Prove I'm Sane.
    Can You Produce Some Too ???
    Madhouse_Dave
    lilitu Guest
    Default recently replaced
    just thought I would say I recently had my timing chain aswell as the tensioner replaced and it took a little over 3hrs, we had trouble getting the heater hose off but other than that it was pretty user friendly unless you have some really hard bolts to undo. I was quoted (by 4 different machanics) almost triple the amount of money that it actually cost, although I think that's because I'm a blonde female?
    Majesticknights's Avatar
    Majesticknights is offline The Dark Prince
    VL HDT Calais Wagon Brock 346 stroker
    Jun 2005
    Montrose, Vic
    lilitu Guest
    yeah, I find it is like that most of the time but I do have a good brake place, but no brake problems, thank god. Think it might be cheaper and easier to find a single mechanic?
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Quote Originally Posted by lilitu
    Oh bugger, I am single but not a mechanic.
    Cheers,
    Jim
    lilitu Guest
    hahahahaha
    But can u fix a car????????
    after doing the timing chain I found after a couple of days of driving there was a bit of oil leaking out the bottom near the sump, so I got a mobile mechanic to come out and fix it, but when he was putting the cover back on
    he cracked it cause he didnt align it properly. I told him he had to buy me a new one but he says that my cover wasnt new so he will replace it with a second hand one from a wreckers. A**hole!!!!!!!!!!!!!!!
    I think he should buy me a new one!!!!!!!!!!!!!!!
    check out the photo!!!!!
    Attached Images Attached Images
    patrix Guest
    yer i agree with you there he should buy you a new one not sum second hand thing . . . he broke it he should fix it . . .
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. timing chain
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 06:09 PM
  3. timing chain
    By howareyou in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 05:49 PM
  4. Timing Chain
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2005, 02:10 PM
  5. VN Timing Chain
    By Michal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2004, 08:39 AM
