Results 1 to 7 of 7
Thread: using fuel
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Default using fuel
    my vn seems 2 b using alot more fuel than it should the engine is stock no mods im not sure if its the fuel gauge playing up can any1 help
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    roughly how many kms to a tank do you get and whats your driving style like ? carry much load at times ?? cruising on the open road or just around town
    Jan 2010
    the km thing on the dash says i get 500 but i hav 2 re-fuel b4 then id say like 400 per tank. idont drive like a race driver i dont very oftern hav a lot of people in the car or weight. i drive both around town and open road bout the same amount 4 each
    VP Executive R-spec
    Jan 2005
    One common thing is the coolant circuit on the ecu being broken, You'll have to take note of how long it takes for the stall converter to lock up after a cold start, it it takes more than a few minutes you have a problem there
    1992 VP vacationer
    Nov 2009
    I get way less than that on my VP. about 200-300 a tank :S It sux and I haven't worked it out yet.
    93 VP Exec series 2
    Jan 2010
    Melbourne, Mulgrave 3170
    replace fuel filter and fuel pump, worked for me.
    change ur cluster if it persists and see if ur gauge is f***ed.
    Common problem for vn's/vp's
    1st Year Beater
    1992 VP vacationer
    Nov 2009
    I changed the whole tank/vapor lines,fuel filter, pump, O2 sensor, fuel regulator, ign lead, plugs, factory type CAI, K&N panel. gauges are not the problem.
    My friend was following me and as I accelerate and he said it continually pours black smoke. Any ideas? ECU reports 12 so I am not sure anymore.
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. VR 5L Duel Fuel Perfect On Gas, Stutters Badly On Fuel
    By djmenow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2010, 11:01 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
