hi my vp commodore has no spark and im not sure why it didi i had it running then turned the motor off then tried to start it again and hen it wouldent start then i checked to see if it had spark and it didnt
Coil pack / DFI module / CAS / PCM / when there is no spark.
Check for error codes first.
Is it cranking at least?
If cranking OK, try with a 7mm socket, remove the DFM wire plug on the side. Corrosion on the pins sometimes causes this and need scraping off. Replace plug, but don't over-tighten, and use Vaso to insulate pins from air, once scraped clean.
Also with plug off, check you are getting 12V at pin 1 (front).
see i spoke to my uncle about it cause he has done work on it be4 i owned it his siter owned it and he said that somtimes that car does that like u could be driving along then all of a sudden it will just die then in 20minutes it could have spark again so its like got power and spark one minute then none the next. I was wondering if anybody body new how much coil packs are for them thanks.
Could be dodgey plugs dodgey leads, dodgey coil pack dodgey alternator not charging your battery.
replace sparkys and coil pack first, cheap easy job, then see how ya go.
1st Year Beater
That was exactly what was happening to me and I already told you what what the possible cause it. Nothing to buy, except if you don't have a 7mm socket. Have you tried it yet? If you are lazy and don't want to scrape off the corrosion, just loosen the 7mm plug bolt and when it happens, just wiggle the plug and it should start again.
See the attached picture. I know the unit in the picture is S1, but it's the same plug for yours.
It could be the CAS. When the car does not have spark as i wrote before will be either the DFI MODULE / COIL PACK / CAS / PCM.
Check if the DFI module has power when the car looses spark this signal comes from the PCM its a pink color wire on the DFI.
If there is power then you can rule out the PCM.
Dont go changing parts and guesing you dont fix cars like this. unless you have a donor. Try to get fault codes out of it. Pins 5/6
oh ok see the thing is is im only young and this is my 1st car and i dnt really no much about them so im doing it all my self so thats y somtimes i get xonfused so sorry avbout that so is that picture is that on the bottem of the coil or where is it exacly cause i couldent seem to find it today when i was looking then ia sked my dad and he said it looks like its on the bottom of the coil but just ask to make sure it is be4 pulling it off just incase it isnt there lol and he cnt really help me cause hes always at work or busy doing other things so im on my own. But thanks heaps for all yours help mate.
its on the bottom of the coils the plug will have a cover on it pull it off mate. ()Bottom right of the coil you will see a loom going into it)
oh ok thanks mate ill have a look tomorrow then.
If there's no spark from all of the coils it can only be the DFI module - which is indeed in the diecast box under the coil pack - the Crank Angle Sensor (CAS), or the wiring between them.
Changing the DFI is easier than changing the CAS but a less common fault.
The advice to check the DFI connection for corrosion is good. Likewise for the CAS connector.
There should be, but not always will be, a fault code set: 41.
I cleaned the coil pack and everything and its running fine but the only thing with it now is after its been running for 20 30 minutes and i turn it off it wont start again till the motor has cooled down
Sounds like the CAS mate. When it does it again pour some water on the CAS (Near the Harmonic balancer)
And see if it starts. If it does then its the CAS mate.
Ok then thanks mate.
Where is the CAS on the car
its on the Crank (bottom of the motor) on the right side of it, by the sounds of things it does sound like the CAS if it runs then gets hot it will die or the car wont start after untill it cools down, So when the car dies get a the hose onto it and hose down the sensor if it starts fine after it then its the CAS.
~ VN POWER ~ Click the scales
