Results 1 to 4 of 4
Thread: vn dash cluster
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Exclamation vn dash cluster
    hey guys im buying a newer dash cluster 4 my vn its a level 3 with the digital screens just wondering wen i buy it and install it will it keep my original kms or will it hav the same as the newer 1 eg. my vns only done 205,000 and the newer 1 has 230,000 will it keep the 230,000 or my 205,000??
    Jan 2010
    is it also posible 2 put in an eletric climate contol into my 89 vn calais instead of the manual one
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Why are you changing the cluster over? The K's are stored in the trip computer so if you put a 230k cluster in thats the K's you will see. If it's a sticky fuel gauge just try and replace the voltage regulator first. If it's bleeds in the LCD's then you can try and swap them over
    As for climate system - you need to splice in the 10 wire plug into your main loom and swap the heater control box. (I've done it to 2 VN's now) It will take you a day or so to take the dash out and replace. There is a thread on convertint to climate control.
    and 3 Dangerous non ABS VN's
    Jan 2010
    can u swap the screens over is it hard? i found a cheap good cluster mainly wont it 4 parts like screen nd stuff could i swap aver the voltage regulator from the 1 im buyin 2 the 1 in car now
  1. VZ to VR Dash Cluster?
    By Wherry951 in forum General Discussion
    Last Post: 27-10-2009, 03:21 PM
  2. dash cluster
    By Burnout_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2009, 08:16 PM
  3. VY SS Dash Cluster
    By buzurk in forum Parts And Other Items For Sale
    Last Post: 12-02-2008, 12:27 AM
  4. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
