Results 1 to 12 of 12
Thread: VN Fuel Tank - Breather hose?!
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Default VN Fuel Tank - Breather hose?!
    Hi guys,
    Sorry if this has already been answered i had a quick browse through the search bar but couldn't find an answer.
    I noticed a fuel leak a couple of days and and just took the drivers side rear wheel off and had a peak only to notice that the hose's attached (well used to be attached) had broken away and are no longer there.. I plan on fixing asap but i cant work out where the hose's go..
    There are 2 coming out of the top of the filler i assume meet up with the 2 on top of the junction box on the filler, then there are 2 coming out of the bottom of the junction box, one of them I assume meets up with a hose coming out of the fuel tank, but I can't fingure out where the other one goes??
    All help is appreciated, diagrams will help ALOT!
    Pictures will be up soon.
    Attached Thumbnails Attached Thumbnails VN Fuel Tank - Breather hose?!-pic_0875..jpg   VN Fuel Tank - Breather hose?!-pic_0880..jpg   VN Fuel Tank - Breather hose?!-pic_0878..jpg   VN Fuel Tank - Breather hose?!-pic_0881..jpg
    VN WAGGY! Bur Bur Bur Bur
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    A mechanic dropped my tank down a little and run a copper tube through the hole in the chassis to the top of the tank. Said I wont have an issue again with the leaking petrol. The top of my tank would be wet with petrol after I filled up.
    So I'm guessing the tube your talking about may infact go to the top of the tank via an indent in the chassis for it.
    and 3 Dangerous non ABS VN's
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Not sure if this link code will work this way, but here goes..
    Image hosting, free photo sharing & video sharing at Photobucket
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    im having the same problem leaks when full. Im gong to lower the tank when its empty and do the whole lot, all new hoses, clean inside with metho and give it a coat of paint to make it pretty.
    BoNeZ-01's Avatar
    Mar 2010
    btw, my pics are of my VR, but should give you an idea of the set-up for your VN, should be pretty similar.
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Thanks for the help guys, going to get all new hoses and replace the lot tomorrow. I think this may of been the reason i'm filling up alot more then usual...
    BoNeZ-01's Avatar
    Mar 2010
    No worries mate, hope that link for my pics worked properly for you, and good luck tomorrow.
    Dec 2009
    I had to replace the breather hoses on my VN sedan which shoudl be similar to a wagon. There were 3 hoses coming fromthe top of the tank to the filler, a large one and 2 smaller ones. The large one is still available from Holden the smaller ones are obsolets so you need to use something else. I used 3mm ID fuel hose from Super Cheap.
    The 2 small hoses fromthe tank go into the seperator/junction you call it at the bottom then fromthe top of that to the filler neck.
    The large hose gose onto the filler neck and ther eis also a line to the front of the car that connects to the charcoal cannister, it is metal and stops just near the rear wheel where it changes to rubber and goes to the filler neck. If you use 3mm ID fuel hose you will have trouble connecting this one back together as the OD of that hose is too big to shove in the 5/16" ruber tube atached to the metal pipe going to the front. I had to make up a double sided hose barb from brass in a lathe. You will also need to get some small hose clamps as the ones on the car won't go over the OD as well.
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Dec 2009
    I've got about 4 or 5 volumes of the GMH factory manuals for a VN with drawings detailing how the hoses go. I can probably scan them in and e-mail if you need them PM me and I will see what I can do.
    Manuals are for sale if anyone is interested.
    Feb 2010
    Quote Originally Posted by wortus View Post
    How much 3mm fuel hose did you buy/ need? do you know the part number or what the large hose is that comes from holden and how much it cost?
    Dec 2009
    You'll need at least 2.5 metres of the 3mm hose. It's not too expensive so get about 3 metres. I just had a look through my records and can't find the docket for the large breather hose I got from Holden so I can't give you the part number sorry, it's just called a breather hose and it's about 10 to 12mm ID and made out of a hard plastic like nylon. Also do youself a favour and get a new hose to join the filler neck to the tank, both it and the new breather hose from Holden (large one) will be tight to get on so just use a bit of vasolene. If I find that docket I wil post the P/N but I am sure a friedn got it for me through this business trade.
    The 3 hoses from the top of the tank need to feed through the chassis rail so make sure you don't kink them, I attached them to the tank and raised the tank on a jack while pulling the hoses through, bolted the tank in place then attached the hoses to the filler neck.
  1. Hose from pot inside fuel tank
    By joe111 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-06-2009, 09:51 AM
  2. VN Wagon Fuel Tank; what is this hose?
    By wez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2009, 05:26 PM
  3. Where do I run a breather hose from my fuel tank to.
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:30 PM
  4. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
  5. Fuel tank breather plumbing
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 04:20 PM
