Results 1 to 4 of 4
Thread: VN Calais - Fuel Consumption on Trip Computer stopped working
    VN Calais V6 / VX S V6 Ecotec
    Mar 2010
    Default VN Calais - Fuel Consumption on Trip Computer stopped working
    Hi All,
    VN Calais V6 on straight gas.
    Recently the Fuel Consumption on the Trip Computer stopped working. The "Fuel Used" does not increase in value and the "Average Fuel Consumption" doesn't change.
    All other functions on the trip computer are still working fine.
    Also (not sure if this is related or not) but around the same time this stopped working, the engine now starts to idle really high once warm - around 2000rpm.
    Any ideas?
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    It might be worth while checking the yellow/black wire that goes to pin 13 on connector 4 on the bottom of the instrument cluster (accessible from the fuse box cover) it should lead over to the ecu behind the left hand side kick panel, that's for the fuel readout issue, as for the high idle i am unsure
    Mar 2010
    Whyalla SA
    on the ecu end it should feed into the space between the gray and the brown/white wire
    Mar 2010
    Thanks Hotweelz, Ill give that a go.
  1. HELP!!! Vr Ute Trip Meter Stopped working
    By Commo_Carl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2009, 09:36 PM
  2. Odometer and trip computer stopped working
    By Dyson in forum Electrical Wiring / Questions
    Last Post: 10-11-2009, 10:49 PM
  3. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  4. Trip Computer - Fuel Consumption
    By ejukated in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2006, 07:45 PM
  5. Help - my fuel gauge has stopped working!
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-10-2006, 12:51 PM
Tags for this Thread
