Results 1 to 6 of 6
Thread: How to replace headgasket v6
    VT SS 5.7
    Mar 2005
    Goulburn
    Default How to replace headgasket v6
    If anyone needs or wants a HOW TO replace driver side headgasket on a series 2 v6 stay tuned and ill post afew pics up later tonight as i will be doing the job this arvo
    Real cars don't power the front wheels, they lift them
    vy 3.8
    Aug 2008
    HI yes id like to see step by step article on this as i want to pull my heads get them ported
    thanks
    victtor
    VT SS 5.7
    Mar 2005
    Goulburn
    Due to faulty camera photos didnt turn out, anyways
    tools needed 3/8mm spanner,10mm socket, 1/2mm socket,16mm socket,15mm spanner,9/16mm long socket,Talk wrench,
    19mm spanner,Flat head screwdriver
    Start with disconnecting the battery and using a 19mm spanner on the tenchen pully release the drive belt
    Un do the bottom radiator hose letting all coolant drain
    using 10mm and 1/2mm start un-bolting the alternater (Will need 1/2mm to remove nut holding wires on)
    disconnect the injector wireing harness and move it away from inlet manifold
    Reaching around the back of the throttle body disconnect the 2 wiring connecters(TPS and IAC)also remove the breather hose that pushes onto the back on the throttlebody (goes to MAP sensor)
    from drivers side remove the 2 little vacume hoses that goto the throttle body
    using 1/2mm socket and 14mm socket unbolt the headderpipes both sides of the motor
    Remove spark plugs 16mm long socket
    The power steering pump hose that bolts to the back on the pump unbolt that (16mm)
    Using a 15mm socket/spanner unbolt the the housing at the front of the motor where the pump bolts onto should be 3 15mm bolts, 1 will be holding the power steering hose and the water pump pipe with another bolt behind them,
    passanger side unbolt the housing the coil pack sits on using a 15mm spanner/socket on Some series 2 and most vp commodores 1 bolt will hold the dipstick in place
    using a 1/2 socket unbolt the thermostat housing,using a 3/8mm spanner start undoign all the inlet manifold bolts (note:there are some behind the inlet manifold and 1 under the thermostat housing)
    after you have unbolted them using a strong grip hold thebck of the inlet manifold and pullit up will be hard to move as you need to break the gasket seal.
    Try not to drop coolant into the vally but somtimes it happens
    Now unbolt the tappet covers using 3/8 spanner/socket
    usign a 14mm or 9/16 socket remove the tappets take not what order they are removed
    now you will ahve free access to the push-rods remove them gently pullingthem straight out,
    using a 14mm or 9/16 socket crack the 4 head bolts you can see in the head where the tappets where,
    Now just under where the headder pipes botl to the head there will be another 4 bolts to crack.
    After all 8bolts (per side) are removed Rember what order they are removed .with a strong grip or with help of a friend lift the head off of the bolt DO NOT DROP IT!(unless you have another headto go on)
    Key notes to rember When reinstalling the heads using loc-tite 242 ithink it is or ask your local repco for the correct loctite for head bolts
    Replace the head bolts if they are rusted
    ALWAYS use NEW gaskets when re installing
    IF you are to use the same heads i will highly advise you on gettingthe heads shaven pressure tested etc or you will be wasting time as the heads have a common problem with warping over the age ofthe motor
    Be patient and take your time
    Thats the finish ,If i have missed anything i will try and add it later unless someone beats me to it
    Vp ss commodore
    Aug 2009
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by Denso View Post
    i think u missed how to put the head back on.......
    its alot lighter to have them off anyway
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    VT SS 5.7
    Mar 2005
    Goulburn
    Sorry kinda thought most peoplewould relise install is the same as the removeal , with EXTRA notes to Heads bolts should be tighten to just firm then further tighten to 81nm
    Tappets should be tighten to 44nm
    best way to tighten head bolts
    5 1 3 8
    7 4 2 6
    After you have re installed everything double check to make sure all coolant lines are connected and tighten correctly then fill radiator with coolant and blled the cooling system
    run car for approx 15min, let cool for 1hour then check compression on each cyl using a compression tester, Standed rating should be arounf 150psi per cyl
  1. VRS headgasket set
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2010, 05:35 PM
  2. Hsvn headgasket
    Last Post: 03-03-2010, 07:11 PM
  3. headgasket questions
    By FuzzY in forum V8 Development and Modification
    Last Post: 11-01-2010, 08:19 PM
  4. Headgasket blown or something else ?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2008, 11:22 PM
  5. Blowen HeadGasket I think
    By darktele in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2005, 01:50 PM
