Results 1 to 8 of 8
Thread: Clunk noise auto gearbox issues?
    zai
    zai is offline
    executive serie 1 1990 VN V6 3,8i 340 000 km
    Mar 2009
    Default Clunk noise auto gearbox issues?
    Hey lads,
    I have this common clunk noise in my gear box when I shift from N to D or even stronger form N TO R.
    I have this noise since I bought the car, I drove nearly 30 000 ks and gearbox still run wells when driving = no noise and quite smooth.
    I often hear such noise on others car such commodore or others cars with auto gearbox.
    After differents search on internet, I wonder what could be the causes.
    Is it normal (I though it is) or is there: an internal gearbox pb, Universal joint, drive shaft, engine mounts.....?
    VN Calais 5L
    Dec 2006
    could be a uni joint, they make that noise. is it a high pitched ting or a deep clunk?
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Mine is a deep clunk.
    When I got the box serviced at 130,000km the bloke shrugged his shoulders and said 'they all do that'.
    zai
    zai is offline
    Mar 2009
    quite deep yes!
    I tried to check the 2 uni joint on the shaft and I don't have any blacklash . Just outside the gear box, around the joint, perhap's 1mm clearance.
    I read so differents stuffs on internet = It's quitte normal, or it's a pb. So that's why I ask the question.
    zai
    zai is offline
    Mar 2009
    I check today with the 2 rears wheels on jack. Nothing from the rear axle, uni joint ok. This noise is just between the shaft and the gearbox, like a play in a bearing.
    Any idea what is this part?
  6. #7
    NO CAR ATM.. -.-
    Jul 2006
    mine clunks real bad its getting worse which feels like the axles are going to snap off
    does that n to d clunk
    n worse n to r
    does 2 tyre marks
    lags on take off
    it hasnt lost performance but clunks like a slut
    when the mechanic checked mine he put it on a hoist, it was in neutral
    he turned the tailshaft quite abit till the wheel started moving had a massive gap
    you cant really tell when ur rear tyres are on the floor
    he said the spider gears the diff centre or some bullshit needed changing
    but im changing everything to be sure along with the 3.45's
  7. #8
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    yeah could be give in your spider gears in your diff... but like previously said, mine also does it, i think your mechanic has the right idea lol
  1. vt auto gearbox noise???
    By bustoff in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 10:47 AM
  2. VX Auto Gearbox Issues
    By Maci in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2009, 05:37 PM
  3. VS Acclaim Auto Gearbox Issues
    By littleholden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2008, 05:04 PM
  4. gearbox clunk
    By burnsy150 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 08:03 AM
  5. Gearbox clunk
    By Soybean in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-07-2006, 12:49 AM
