Results 1 to 6 of 6
Thread: what checks before LONG road trip in my 91 VN?
    VN EXEC
    Feb 2010
    Default what checks before LONG road trip in my 91 VN?
    hi guys, this might seem slightly stupid to some of you so sorry in advance for wasting ur time, but
    im going on a big roadtrip in my second hand VN wagon, ive recently changed the radiator and hoses and cooling system seems to be fine. I just want to know very general things about basic or important checks i should do before going on a long road trip/journey where i might clock up to 5,000 -10,000 km....i hope the car will last! also i run it on LPG- well its a dual system.
    anythng you can suggest....
    thanks
    Dec 2009
    I'd be checking the following;
    Brakes
    Front and rear suspension suspension
    Repack front Wheel bearings or at least check them
    Fluid levels ie diff
    Fresh engine oil
    Service the auto
    Check tyres for any damage
    Take a good tool kit
    Fuel pump and filter, if you don't know how old the pump is get a new one.
    Check universal joints
    Check under car for any leaks, damage etc
    Take of drive belt ad check the condition of the alternator bearings and water pump
    Take out alternator regulator and see how much of the brushes ar left if worn take a new regulator or spare alternator
    Replace the engine coolant if it needs it
    Load test the battery
    VN EXEC
    Feb 2010
    ok whats the bear minimum....im definitly not knowledgable or able to do all that! but thanks for such a comprehensive list...
    bare minimums?
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Just change your oil and filter, make sure you have pleanty of driving music, pack your tool kit and have a good time. VN's where made for the long trips so she should last.
    1990 VN Wagon
    Apr 2010
    id do what wortus said but if not and you want just basic stuff , change your plugs to when you change your oil .. or do what i did ... did a FULL service and tune on it that way i knew that the motor and transmission was ok then just check for any leaks that are concerning and check tyres and brakes and all fluid levels and top up and replace what is needed hope that helps ..
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    if you can, grab a copy of the gregorys manual for it, a lot of people have them so you might be able to borrow one. It could help get you out of trouble if you're in the middle of nowhere.
    Also, consider (temporarily) upgrading your RAA coverage to give you a longer range tow etc..
  1. Planning a road trip
    By SAV_117 in forum The Pub
    Last Post: 08-05-2009, 03:44 PM
  2. ROAD TRIP!!!! (Canberra to VIC)
    By azkwazere in forum The Pub
    Last Post: 09-04-2007, 05:31 PM
  3. Yet Another Road Trip To Get A XR6T
    By fabz in forum The Pub
    Last Post: 02-12-2006, 07:23 AM
