Results 1 to 8 of 8
Thread: vp v6 cutting out wont rev past 2500rpm cas? coils packs?
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    Default vp v6 cutting out wont rev past 2500rpm cas? coils packs?
    hey
    my v6 is idling like this
    IMG_0138.flv video by holden_boy6 - Photobucket
    it only idles like that some times but normaly when it starts playing up
    and when i drive and i hit 2500rpm it sounds like the rev limiter
    and it also cuts out and then wonts start again
    i checked if it had spark and it didnt but it does now
    if the crank angle sensor was buggerd would that stop the spark
    i have also ruled out tthe fuel pump and the leads and spark plugs as i replaced them last week end
    thanks in advance for your help
    vx s pack II
    Jan 2010
    aLKIDA
    CAS can cause no spark mate. When the car does not start or when there is no spark then pour water over the CAS (Near the harmonic balancer)
    If the CAS is totally stuffed up then there will be no spark.
    It also can be the DFI module the coils sit on top of it.
    But Sounds like the CAS mate
    1992 VP vacationer
    Nov 2009
    whats the ecu say? have this same problem on my bro's EB ford (problem solved! we are dumping the ford )
    vpcalais6's Avatar
    V6 manual vp Calais
    Sep 2007
    central coast
    Quote Originally Posted by PRAVX II S View Post
    when the cas is stuffed is the problem normaly intermiten
    looks like ill be changing the cas tommorrow and i will change the dfi at th same time just incase
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by vpcalais6 View Post
    Yes it can be intermiten mate. I would suggest you wait till it cuts out again then pour the water over the CAS and then see if it starts.
    Dont change the DFI module unless thats the problem get the most use out of the old one mate.
    But its up to you mate
    vpcalais6's Avatar
    V6 manual vp Calais
    Sep 2007
    central coast
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Repalce your Coil packs. If it is/was the crankshaft sensor, you can always 'test' it when/if the engine actually cuts out by pouring a cup or small bottle of cold water over it. If the sensor is faulty the engine will usually start. If the coils are faulty no manner of 'intervention', short of complete replacement, will get them working again.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by Benboy View Post
    That is not entirely true. Some times the CAS can stop working no matter how much water you pour. (18x / 3x signals)
    When a car comes in a work shop we don't just change parts just for the sake of it or because we think its going to bugger up anyway. If that was the case we would change all the parts in the car.
    With a big price tag on it the customer wont be happy.
    To properly test the CAS you would need a oscilloscope and check the pattern its giving out but obviously you would need a oscilloscope.
  1. Vt Executive wont rev past 2k
    By rob2190 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2009, 10:26 AM
  2. speedo wont go past 110kms
    By vsutee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2009, 07:47 PM
  3. engine noise past about 2500rpm
    By alex2_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 07:24 PM
  4. wont rev past 2250
    By Panama in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-09-2008, 11:15 PM
  5. VR V6 auto wont go past 2nd gear
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 12:01 AM
