Results 1 to 7 of 7
Thread: Clunk while applying power, changing power etc.
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    Thumbs down Clunk while applying power, changing power etc.
    hows it goin
    i have a VP V6 5 speed manual ute.
    when i go to take off, change gear, put my foot down and even take my foot off the accellerator (engine breaking), i get a slight clunk in the drivetrain.
    also say im going to slow for a gear and the car is about to stall and 'kangaroo hopping' it makes a very loud ching ching ching metal on metal noise everytime the car jolts forward, so there is obviously slack in something.
    my first guess is engine mounts but is there any other mounts i should be taking a look at? are engine mounts a hard job to do at home with basic tools? (if its relatively simple ill be able to do it)
    cheers, sid
    93 VP Ute, V6 5 Speed
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Have you checked your uni joints on the tail shaft?
    Illegitimi Non Carborundum
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    have you checked for give in the diff? basically just get underneath and check for give in as much of the drivetrain as possible by grabbing the tail shaft and trying to turn it. uni joints would be your first bet. also check you're centre bearing mount in nice and tight and that there is not too much give in the rubber surrounds in that... and also do you have a larger aftermaket exhaust? sometimes if you get a vibration through the tail shaft it'll actually knock against an aftermarket exhaust system...
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    a clunk when applying power and then another when lifting off the throttle indicates a stuffed uni. most likely the one that attaches the drive shaft to the diff.
    Body by Holden, Soul by Brock
    the Legend will live forever
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    My LSD is really rooted and its making similar noises. What are uni joints?
    Apr 2006
    Auckland NZ
    universal joints
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    or CV Joint.
  1. Changing power steering fluid
    By Sean880 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-12-2009, 02:58 AM
  2. Changing from power to manual steering....
    By broderikb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2006, 08:50 PM
  3. Power from changing exhaust
    By vyaw2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 08:51 PM
  4. Changing power steering hose.
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2005, 02:39 PM
  5. Changing Power steering pump
    By Gav95VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 05:12 PM
