Results 1 to 3 of 3
Thread: VN V6 running rough
    vn and vx
    Jun 2009
    Default VN V6 running rough
    Hey fellas, i have a VN 6 that running pretty rough- sounds like volkswagon and feels like its driving over a road made of corrugated iron. It's sluggish, idles ok and still does 100Kpa
    No smoke and not running hot although seems like more heat is thrown out from underneath the car.
    Yesterday i replaced the MAP sensor when i read i had a code 33 error. After replacement the car ran sweet and i only got a code 12 after resetting the computer.
    Tonight i was driving, all fine then it started running crap just like yesterday, felt like i was running out of fuel and now i get a code 22- TPS.
    Could a TPS cause a car to run this bad?
    Could a stuffed cat cause the car to run bad? The reason i ask is there seems to be a bit moor heat under the car and a strange hot smell..........Cheers
    vn commodore s2 BT1
    Mar 2010
    could be mate mine ran like shit wen i swapped over throttle bodies and the tps was shagged i put a new one in and still going after 6 years
    vn and vx
    Jun 2009
    Quote Originally Posted by vn calais lookalike View Post
    Cheers mate, I swapped the TPS, cleaned the throttle body and it runs sweet again
  1. VR V8 running rough
    By gemilover in forum Tuning
    Last Post: 16-06-2009, 07:52 PM
  2. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  3. Need help with a rough running vn
    By gnomie1979 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2008, 10:54 AM
  4. Help! VL running rough
    By charlene in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-11-2007, 07:12 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
