Results 1 to 3 of 3
Thread: vp motor ticking
    vp
    Apr 2010
    Default vp motor ticking
    hi everyone,,
    i have a vp v6 and the motor is ticking, i have been told its the tappets or lifters. When i accelerate it ticks and when i let go it stops.
    just wondering if it is a big job to replace them and a rough price on the parts.
    Also im looking for more power, it goes good as is, iv dun pod filter and 3' exhaust cat back with hi flow mufflers and cat, and a 3:4:5 lsd diff.
    what would be my next few steps when searching for that bit more power
    Thanks mikky
    Vp ss commodore
    Aug 2009
    probably for more power id go bigger injectors, tune and maybe a double throttle body or sumthing. should see if u can slap one of those vt calais super chargers on it with a smaller pulley.....
    VN S1 (was VR) V6 Hilux
    Apr 2009
    I had ticking and ignored it for a year. At the same time, it was using heaps of water. The water was leaking in the valley into the oil. Check your oil cap for cream.
    The ticking was from either the blocked lifters or push rods not allowing oil to go to the rockers. I cleaned and fixed it, but the ticking remains - there is some serious wear in a push rod or rocker. These are not adjustable and the fix is to remove the rocker cover, pull out the push rod and replace it with the affected rocker.
    If this is not your problem, then it is a stuck valve.
    If your ticking is actually a knocking, then your problem is a worn big end bearing - big problem!
  1. Ticking behind dash (no, not injectors or lifters ticking)
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 01:20 PM
  2. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  3. motor ticking noise
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2008, 12:50 PM
  4. motor making ticking sound
    By TINYTIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 09:47 PM
  5. Ticking sound in motor!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 09:06 PM
