Results 1 to 5 of 5
Thread: bad shudder driving me mental... can't find the answer
    VN Berlina
    Aug 2007
    Carrum Downs
    Default bad shudder driving me mental... can't find the answer
    hey guys.
    I've got a pretty bad shudder/vibration in my vn berlina and its driving me nuts because i don't know where it's coming from.
    Reco engine about 3 months ago so i'me pretty sure its not engine related.
    Whilst cruising at about 2000rpm its a consistant on and off shudder about 1-2 seconds between each vibration.
    my mechanic has checked the engine mounts tailshaft bearings and i've double and triple checked the harmonic balancer to make sure i put the right one back on.
    can anyone give me any insight??
    could it be loose torque converter?? or something else.
    only other thing i can think of is about 3000km after driving new engine was on fairly long distance drive and my o2 sensor went at 4am on a sunday so i had to drive another 500 km's home with it running rich and fairly rough. could this have damaged anything e.g. crank?
    any feedback would be much appreciated
    cheers
    Vn commodore executive
    Mar 2010
    Check your exhaust system mate... When i first bought my vn s2 bt1 it had the same sort of shudder, it was the cat vibrating against the under body
    i'm not tailgating, i'm keeping up with the pace car
    vn and vx
    Jun 2009
    An unbalanced wheel can cause vibration at certain speeds, see if any wheel weights are missing -look for a clean patch on your wheel where a weight might have been. or look for a dent in the rim.
    Check tail shaft it tight at uni joints and look for any damage.
    As mentioned above check your exhaust.
    If you think its coming from the engine check the error codes...cheers
    Vp ss commodore
    Aug 2009
    where is the shudder coming from... e.g. through seat, through floor pan, through shifter, through steering wheel, from back or front of vehicle? does it get worse when turning corners? i dont belive running the engine rich is going to damge it unless it was detonating for 500km's lol check the water pump pulley is tight and the water pump is not old/ leaking (i know its a reco engine) i had a supra and the water pump was buggered nd it sent a pulsatiing vibe through the car.
    VP HSV Senator 5000i
    May 2008
    Auckland
    I had the same frustrations, after the trans company inspecting the trans, then the mechanic suspecting possible worn camshaft lobes. A few months later whilst getting a WOF I had the rear transmission mount replaced (NB: Mechanic & Trans comany thought was old but looked fine), now there's still a small vibration so cam is probally worn as engines done 260K, however the bad shaking that started arond 1500 rpm & just increased disappeared.
  1. [LS1] Help...I searched and couldn't find the answer to my OTRCAI "issue"
    By hwy747 in forum LSx Development and Modification
    Last Post: 14-01-2010, 06:01 PM
  2. Driving lights - where can i find the signal wire source?
    By OzRod in forum Electrical Wiring / Questions
    Last Post: 22-01-2007, 08:33 AM
  3. Mental Hospital
    By Blown V6 Hatch in forum Jokes/Humour
    Last Post: 08-02-2006, 02:38 PM
  4. Cannot find the answer - Fuel/temp gauges, warning lights
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 07:40 PM
  5. ok ok im going mental now
    By anfsvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-10-2005, 11:14 PM
