Results 1 to 12 of 12
Thread: bad steering in vp
    vp s2
    Apr 2010
    Default bad steering in vp
    trying to work out whats wrong with the steering in my VP ya hit bumps on the road and the steering goes mental really pissing me of i cant work out whats wrong Ive replaced the sway bar link bushes and the radius rod bushes the tie rod ends and ball joints seems fine no movement at all until you get it on the road then its all over the show any idea's let us now. cheers
    vnss
    Jan 2005
    s.e melb
    steering rack then.
    its hard to give you proper advice without much info, all you say is that it "goes mental" and "its all over the show".
    vp s2
    Apr 2010
    sweet cheers bro i checked the steering rack all seems good wheels respond good when turning the wheel no slop in the steering wheel itself everything seems firm until i get it on the road then its just a different picture it just goes from side to side like the wheels have got a mind of its own and steering is reel loose but yet again its all good underneath every thing seems good how would you recommend to check if the rack is all good
    VK V6
    Mar 2010
    NZ
    vp s2
    Apr 2010
    1992 VP vacationer
    Nov 2009
    does in shudder bad? when turning sharp to the point where the wheels are slipping
    vnss
    Jan 2005
    s.e melb
    too much toe out will make it track like a bitch and if its low and got wide tyres on it its even worse.
  8. Default
    what wheels/tyres are you running? i had the same problem in my old vn and i was running VT SS'. pedders said they were the wrong offset (not sure if this is true or not), and also because they had wide tyres it put a lot more strain on the suspension. so i put on a set of stockies and the steering was a million times better after that. worth a shot of you're running big wheels!
    Quote Originally Posted by zai View Post
    I am not sutpid
    vp s2
    Apr 2010
    yea when i turning full lock it feels like the front wheels are slipping bit they just wanna go there own way when going about 80ks goes left to right pretty badly hit bumps and throws ya on the other side of the road pretty quickly and steering loose and gotta fight against the wheel fair bit but everything seems firm under neath got under it and nothing seems loose when turning the wheel running 17ns on it but no better with stockies
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    Soft or worn Z bar bushes can make them track all over the road. I had this problems with one of my VNs and when I put new nolathane bushes in, it steered like a sensible car.
    Another symptom of worn Z bar bushes is excessive front tyre wear
    VK V6
    Mar 2010
    NZ
    Quote Originally Posted by punisher451 View Post
    its due for a wheel alignment but it seems more major than that
    Problem is you really don't have any idea what you're dealing with until you at least know what's going on with the alignment though - you could have something bent that's getting it way out of whack, who knows...
    92 VP Series 2
    Jan 2009
    East Brisbane
    hey mate, sounds like you and me have the exact same problem. i have got my car checked out and pedders reckon my front lower control arm bushes are all scragged and my strut mount tops are cracked. so maybe just check out your strut tops (you can see them when you open up your bonnet) and just see if they look all worn and cracked. just a thought, good luck mate.
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  3. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  4. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  5. Speed sensitive steering to exec steering??
    By pest in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2004, 08:50 PM
