Do i really need this because its not working now....Just Stopped....Help....Thanks![]()
If you ever need a new blue slip or needs to go over the pits, wont they need a odo reading?
I know they want odo reading for pink slips..
About as handy as tits on a bull
It wont hurt the car, unless it bothers you don't worry about it too much. Just put it on the to do list and fix it whenever but its not too important.
its an easy fix. just a new unit from the wreckers. It would bother me not having one.
If its a simple fix like the fuse or something easy then i would get onto it.
its that little rubber gear inside the speedo. change that and you will be fine.
The Daily VN T5V6
355 VN GRP A REP
hahaha thats true .. If they dont know its not working they dont pick on it .. But rule of thumb is, if it dosent work and it should, needs to be fixed .. if its not factory, its not suppose to be there .. Not saying they do this but a few places wont pic on a simple ODO not working as it doesnt affect anything vital on the car
Here you go champ.. Fixing your ODO is VERY EASY!
You will need a replacement cog tho.. Recommend, you look on eBay or ask your local wreckersThey are cheap, $10-$17 on ebay..and wreckers normally sell em for $10 if that
Here is the How-To ,
Fix Your Broken Odometer
Good luck!
