Results 1 to 22 of 22
Thread: Magic booster to improve fuel consomption??? does it works?
    zai
    zai is offline
    executive serie 1 1990 VN V6 3,8i 340 000 km
    Mar 2009
    Default Magic booster to improve fuel consomption??? does it works?
    eBay Seller: jpnona: Cars, Bikes, Boats items on eBay Australia
    Does someone know anything about alternator, electricity and battery?
    You just have to plug this to your battery and your engine will run better with a better fuel consomption.
    So??????
    Sabbath''s Avatar
    Sabbath' is offline McKennock
    80 Series TD Landcruiser // Hustler
    Jul 2006
    Crap.
    Wouldnt waste my time or money on it.
    Quote from the seller page in the feedback:
    "00 3.8L Camaro, runs 2km more per litre!!!!"
    1992 VP vacationer
    Nov 2009
    scam!!!!!!!!!. stay away from stuff like that on ebay. you made me angry now! I should of not read that garbage on that link you got there. Makes me so angry what these people claim this crap can do.
    zai
    zai is offline
    Mar 2009
    yeah but it's like free. If you don't like it you just have to return and they give your money back (+ postage x2) so you don't loose anything except your time.
    I was on the way to buy one but I prefer to ask people who know before to be sure.
    1992 VP vacationer
    Nov 2009
    If you want to save fuel you might want to try to make a fuel pre-heater. I hear they work pretty good.
    The idea is that warm/hot fuel atomizes far better than cold fuel thus combusting better.
    I would like to see someone make one with a trip computer and see what difference it makes. Question is, what sort of long term effect does this have on injector performance/life. Will they last longer or shorter?
    If you want to make one and test it that would be good info right there.
    here this will give you an idea.
    YouTube - Fuel Pre Heater Prodgect for 89 Ford Mustang
  6. Default
    if it worked, then it would be fitted to cars from the factory. do you think manufacturers would spend millions of dollars on research and development for fuel economy when all they needed was a $40 device off ebay?
    this is how it works. you fit it to your car, and expecting good fuel economy, you subconsciously drive your car a bit slower than you normally do because your mind associates good economy with driving slow. you fill up, realise you got better economy, and think the device worked. in reality it is a placebo.
    Quote Originally Posted by zai View Post
    I am not sutpid
    zai
    zai is offline
    Mar 2009
    "do you think manufacturers would spend millions of dollars on research and development for fuel economy when all they needed was a $40 device off ebay"
    This one is not a fake!!! and where are the manufacturers!!!
    Check it:
    \GEET Friends Net
    http://www.geet.nl/
    http://www.geet.nl/GEET_Single_autop...0ccbec14c0Free
    I have seen car working with that system! More power, less polution and better consomption!
    You just need some materials and water, no more!
    that's why I ask the question for this little 40$ stuff. Who knows
  8. Default
    geet is a scam. if it wasn't, everyone would be running the system. he provides the instructions for free anyway. if it's so simple and easy then why don't you have one on your car right now?
    I am not sutpid
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    zai
    zai is offline
    Mar 2009
    I didn't do it because I don't have tools and time to do it. And alone it's not so easy!!
    And it works fne on little/simple engine but on a V6 fuel injected, I don't now.
    It's still a prottotype.
    Dailymotion - Voiture
    This is a top french TV news program. A mayor from a little town has installed this system on the council's car to use less petrol and produce less polution.
    I have plenty like these one if you want!
    zai
    zai is offline
    Mar 2009
    Anyway, that 's not the question there. For this "magic booster" I should perhap's post on the general forum and not only there and ask people who have knowledges about battery, alternator and electricity. An engineer could know the answer.
    TVR-190's Avatar
    TVR-190 is offline You went full retard.
    Canyonero
    Jun 2008
    N.S.W
    save your time, it will be deleted. like this thread
    Can you name the truck with 4 wheel drive, smells like a steak and seats 35?
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    It is made with 100% japanese best grade electronic parts (It is designed like a big electronic part)
    Really they build electronic parts to look like electronic parts. Modern technology at its finest.
    This unit suits for all cars and motorbikes with a battery of 6-12 volt. (Gasoline, LPG, diesel)
    My battery sits on 12.4V, and has 14.4V when car is running. WHAT WILL I DO DAMMIT!
    So it connects the positive and negative of your battery, LOL I can see that going bad. I once had my spanner touch both terminals at once, and my hand can attest to that generating a lot of electricity.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Now with my very own Tech2....YAY.
  15. #15
    1992 VP vacationer
    Nov 2009
    Quote Originally Posted by sik_dose View Post
    Im keen to try the Fuel preheater.
    Yeah me too. I know this should have some effect on combustion as this is a thing based on the old carby days.
    lol remember when you would pump the carby while the engine was hot while off and looking down the carb. I remember hearing the fuel boil away and turn into pure fog. so I am guessing fuel coming out of the injectors at 90oC
    would atomize pretty much instantly as appose to a mere 25oC or so. A custom tune maybe need to maximize the benefits as fuel becomes less dense from expansion due to heat.
  16. Default
    you've just linked me to a french video that i can't understand that shows the completed system. a completed system does not mean it works. anyone can say anything by spewing a bit of guff that other people don't understand and get it on tv, they showed no evidence at all that it actually worked (except for 2 rags, one dirty, one clean. that's not evidence). how about you link me to some hard scientific evidence from a reputable source that proves that it works? you can't, because the only 'scientific' evidence proving it works was conducted by the creators of the product.
    if it worked, everyone would be talking about it, and everyone would have one. but not one single person on any of the car forums i am on has this system. if i could save as much fuel as they say the system does, i would be making the time and getting the tools to put it into my car, and i'm sure other people would too.
    I am not sutpid
  17. #17
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, LC200, VP SS
    Aug 2004
    I reckon this thing will work just as well as removing the cat off my zorst - Is louder and feels faster so therefore it is
    Reaper
    Reapers 300rwkw Daily Work Hack
    Reapers Black VP SS
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  18. #18
    zai
    zai is offline
    Mar 2009
    "it worked, everyone would be talking about it, and everyone would have one. but not one single person on any of the car forums i am on has this system. if i could save as much fuel as they say the system does, i would be making the time and getting the tools to put it into my car, and i'm sure other people would too"
    up to you mate, this topic is about this "magic booster" not about the systen I just showed you for your interest!!!
    The pantone sytem is a fuel pre heater! You don't use water as propellant
    If you are a bit curious, you will find plenty of website and people with this system in their car but like I said it's still a prototype that works fine for little engine without EFI. You"re just one more sheep that believe the gvt, the car's manufacturers and the oil producer. Do you think these people are happy to see your vehicule can work better with FREE water that means less tax for the gvt, less money for the manufacturers (no more cat in your car!! for example), and even worse for the oil producter.
    To finish, the pb in France is your are not insured if you have this system in your car!!!! And that's a BIG PROBLEM!!! Imagine you have an accident where your are not responsible. If someone died you will pay until the rest of your life!!
    Other example, cars working with frying oil!! this one is quite famous too. And same pb you are not allowed to drive with this fuel otherwise police can arrest you and give you a big fine!
    Now if you have some scientific knowledges about my topic you are welcome.
  19. #19
    Sabbath''s Avatar
    Jul 2006
    Are you interested in our opinions, or just spurting more sales pitch crap back at us?
  20. #20
    zai
    zai is offline
    Mar 2009
    so what's your "scientific" opiinion on this "magic booster" if you have one? that's the topic!
    I am not sutpid and I know it's certainly a booby trap like plenty other one but as I don't have any knowledge I ask people who can give me some GOOD answers and not reasonning that I have myself THANKS
  21. #21
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Quoted for truth
  22. #22
    Nov 2003
    What a crock of crap. If you look at the ebay sale it's a matter of undong the termail screws and attaching the item to each termal and screwing it back on. It also say 2 minute job. I find it hard to believe you don't have a tool (besides yourself) that will undo the battery terminals and 2 minutes of your time.
    I don't understand you ask for advice then argue when people say it's crap.
    It reminds me of the bloke at work who asked the financial controller if the 10000 $$ he was about to invest was a scam. It was advised it was a scam. The guy went ahead with the 10000$ racing investment and lost 10000$. It amazed me how he swore black and blue it wasn't a scam even up to the day he found he lost is money.
    I say just be done with it and buy it and not waste forum space arguing why should. I find your posts on the subject all over the shop.
  1. HTC Magic
    By Jesterarts in forum The LAN Lounge
    Last Post: 29-01-2010, 01:39 PM
  2. Replies: 13
    Last Post: 14-05-2009, 02:06 AM
  3. VT has flat spots on fuel, works FINE on LPG???
    By lordmuz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2009, 06:49 PM
  4. VX headunit works and doesen't works
    By kaishiz in forum Car Audio
    Last Post: 13-09-2007, 12:38 PM
  5. Fuel economy How to improve look ere
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2006, 09:21 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
