Results 1 to 11 of 11
Thread: Air Conditioning Not working Properly!!!
    VN S Manual
    Jul 2009
    Default Air Conditioning Not working Properly!!!
    i have recently tried to hook my air con controls back up after having the centre console out to install my electric windows. I plugged in the air con switch and pushed it to on. I installed the two power plugs on the back of the heater controls, and the vaccum hoses. I then turned the ignition to accesories and pushed the fan speed to 3 or 4.
    I got air coming out, however its only of the footwell. when u turn the spot selector (vaccum hose part) no changes happen it still comes out of the footwell no where else.
    Any suggestions? I must have something wrong somewhere!!!
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    You may need to start the engine to build up vacuum for the vents to work.
    VN S Manual
    Jul 2009
    oh ok really, is that how the vaccum works? there wasnt enough charge in the battery to start, ill charge it up and start he rup. so i should run it for a while to start the pressure back up?
    How does the engine cuase the vaccum to biuld up?
    thanks heaps
    VN S Manual
    Jul 2009
    also for the air conditioning to work do i have to have the engine running?
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    VN S Manual
    Jul 2009
    alright will run the car and see if that fixes my vaccum problems, fingers crossed.
    1992 VP vacationer
    Nov 2009
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    From the way I understand it, there is a tube that runs from somewhere on the intake manifold, to gain a vacuum from it, it hooks up to to the vacuum ball, which holds like a 'vacuum charge' to operate the vacuum controls for your heater and stuff.
    But also, behind where those controls are, there may also be a metal rod coming off the back of those controls which needs to be hooked up(not sure about VN/VP), to operate one of the vents.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    VN S Manual
    Jul 2009
    there is a metal rod but its t control the hot/coldcontrols. Ill start the carup and see what happens. thanks for everyones help!
    BoNeZ-01's Avatar
    Mar 2010
    D'oh! It is too, I forgot about that, it's also for the hot/cold on mine too..
    VN S Manual
    Jul 2009
    everything is working perfectly now. Had it set back up just had to run the car. Only problem now is gluing my metal rod to the plastic part that it holds in, as mine broke!
  1. Tacho not working properly?
    By johnvncommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2010, 10:02 PM
  2. Speedo not working properly
    By bludeck in forum ASR Audio & Electronics
    Last Post: 19-07-2009, 12:02 PM
  3. Windows not working properly
    By killuminati in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 12:04 AM
  4. VR Aircon not working properly
    By VRS_Dave in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 09:05 AM
  5. antenna not working properly
    By Cameron in forum Car Audio
    Last Post: 15-03-2006, 10:03 PM
