Results 1 to 12 of 12
Thread: VN Wont start, grrrrrrrrrr
    VN Exec Wagon
    Mar 2006
    Default VN Wont start, grrrrrrrrrr
    VN Manual wont start.
    When driving it felt like it was missing then just died completely.
    Turns over but wont fire. Not even a cough.
    No spark?
    Replaced CAS
    New Battery
    New coil pack
    New plugs
    Error code reads 12
    Fuses OK.
    Fuel pump works
    Dont know what else to check.
    Any help would be most appreciated, thanks.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    How about the DFI unit - was that replaced when the coils were?
    and 3 Dangerous non ABS VN's
    VN Exec Wagon
    Mar 2006
    Quote Originally Posted by 88GreenVN View Post
    Yes a complete unit was installed.
    WK Statesman V8
    Mar 2010
    vx s pack II
    Jan 2010
    aLKIDA
    You say there is no spark (Did you check for spark at the leads?) The only thing that controls the spark are the Cas,DFI module,coils,Obviously leads and spark plugs. Check the connection on the DFI module was the little bolt screwed in properly on the DFI module connector?
    Check the EFI fuse and relay as well. could be no injector trigger. The relay supplies power to the injectors and the PCM supplies earth to the injectors
    Check if you are getting these signals.
    VN Exec Wagon
    Mar 2006
    Quote Originally Posted by PRAVX II S View Post
    Yes checked for spark at the leads.
    Did a multimeter test as per forums on the replacement DFI-COIL unit.
    Bolt is tight and connectors clean.
    Checked fuses/relay by swapping with a know good one,horn.
    Pulled fuel hose off to see if fuel pump was working. Yes works.
    Stumped and thank you.
    VN V6 S1
    Jan 2010
    Queanbeyan NSW
    This might not help, but my VN was doing the same thing last month
    It was turning over but wouldn't fire everything was in good condition, i replaced all the leads, plugs and the DFI/coil pack aswell, but no luck.
    turns out that the throttle body wasn't lettin enough air (almost nothing) in as there was a huge collection of carbon built up around the walls, as it only has a tiny gap for start up, enough to get blocked.
    after it was cleaned and all the crap was removed it start perfectly.. apparently its pretty common, im not sure... might help.
    Cheers Tim
    VN Exec Wagon
    Mar 2006
    Quote Originally Posted by TimmyVn View Post
    Cheers Tim
    Thanks will pull it apart and see how it goes or not
    vg commodore
    May 2010
    i have the same problem i would like the same to get it started but it wont so goin to rebuild the motor and put a turbo on it
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    my vs died on me a while back, had spark, fuel, injector pulse etc but no go. turned out my negative lead was loose at the motor, tightened it up and it ran perfect. maybe check the state of your battery cables/earth contacts etc
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Check that you have 12 volts or more when ignition is on on this pin on the DFM plug;VN Wont start, grrrrrrrrrr-pins-small-.jpg
    I know this a S1 DFM and coils, but the S2 is the same pin for power supply to have spark. Also, if you have power here, check there is good earth return and also one of the wires going to the CAS might be broken - this means you will have no spark timing!
    VN Exec Wagon
    Mar 2006
    Quote Originally Posted by v6lux View Post
    Check that you have 12 volts or more when ignition is on on this pin on the DFM plug;Click image for larger version.
Name:	pins (Small).jpg
    Thank you. I will check this out.
  1. VL wont start
    By vlcalais11 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-02-2009, 09:54 AM
  2. Car wont start
    By pickletime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2008, 07:01 AM
  3. Car wont start
    By matty_kar in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-07-2006, 11:32 AM
  4. Car wont start
    By jonathon_86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2006, 03:27 PM
  5. Help Me, Car wont start!!!
    By Bleaaargh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2006, 05:50 PM
