Results 1 to 3 of 3
Thread: vp manual problem
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    Default vp manual problem
    i have a slight problem with my vp manual wagon, starts and idles fine when you touch the accellorator to rev it it kinda like missfires/ runs rough for a second then the revs build up as usual then the same thing when you take your foot back off the acellerator, i though it was the throttle bottle so i took it all apart and cleaned everything, its nice and shiny now no carbon anywhere to be found yet it still has the same problem, it has new leads as far as i know but im not 100% sure on the plugs ill pull them out and give them a look, is there anything else i should check?
    Whiteford88 is offline 38PONT
    Holden Commodore VN V6
    Jan 2010
    Tamworth, NSW
    First establish what type of problem it is:
    Computer or Mechanic
    Test the computer for error codes before screwing around with your engine.. cause the more you toy with it the more chance you have to break something else, and I learned that the hard way didn't I lol.
    So go back to this page and find the "How to get codes" or watev, its REALLY easy.
    Then if you get 12 (12 means everything is OK as far as the puta goes.)
    Other then that it's got me ****ed (:
    1992 VP vacationer
    Nov 2009
    check the ECU codes. could be TPS??
  1. Vs manual problem
    By AussiePride in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2009, 05:47 PM
  2. manual vx problem
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 05:29 PM
  3. Problem with Manual VY
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-08-2008, 02:51 AM
  4. vx manual problem???
    By commodorecountry in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2008, 12:10 PM
  5. manual t5 problem
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 11:03 AM
