Results 1 to 6 of 6
Thread: 5ltr ignition leads
    97VSS2's Avatar
    97VSS2 is offline CRABWALKIN CALAIS
    vn calais 5L
    Jan 2009
    canberra
    Default 5ltr ignition leads
    what is the easy way to change the ignition leads.... or is it as hard as it looks???
    thanks heaps blake
    90' vn calais V8
    if sparks dont fly, your rides too high
    Holden VN SS
    Mar 2010
    97VSS2's Avatar
    vn calais 5L
    Jan 2009
    canberra
    great, any tips that might help???
    cheers blake
    90' vn calais V8
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I took the transmission out
    Oh and dont do it when the engines hot
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Holden VN SS
    Mar 2010
    use a flathead screwdriver to pop the clips off the cap & a torch to see what your doing back there. Its easier to change them with the cap lifted up & possibly out depending on how you go.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    its not that bad really, yeah it's a pain in the ass but it could be worse. like old mate said, dont change them when its hot unless u got a really high pain threshold!
    all i did was take the engine covers off, pull the leads off the plugs, get the cap off the dizzy and somehow squeeze it up between the firewall and manifold, its a tight fit, the rotor button was in the road so wound it over a liitle until the rotor button was in a spot where it wasn't in the road. keep trying and you'll get the bastard out.
    installation is the reverse, just have a good look at the vacuum lines etc at the back of the motor where you've been working once its all back together, just in case one got knocked loose
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
  1. Top gun ignition leads?
    By Skidney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2009, 05:57 AM
  2. Ignition Leads
    By Dougeh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2009, 11:20 PM
  3. F/S Leads To Suit VB-VL 5Ltr
    By Sik_Cordz in forum Parts And Other Items For Sale
    Last Post: 22-03-2008, 03:47 PM
  4. Spark Plug leads Vk 5ltr
    By Sik_Cordz in forum V8 Development and Modification
    Last Post: 05-03-2008, 08:15 PM
  5. Ignition Leads?
    By Torniquet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2006, 10:33 AM
