Results 1 to 5 of 5
Thread: remove the throttle body
    vp cxommordore
    Mar 2010
    Default remove the throttle body
    Hey everyone iw as wondering if its hard to remove the throttle body on a vp commodore to clean it and what do i clean it with?. Thansk heaps
    vr commodore
    Apr 2007
    removing it is easy as if you look at the throttle you will see a bolt that holds it on the then underneath will be another unplug the icm and tps and the map sensor hose and it will come str8 off and i normally clean it with degreaser or wd40 brings up the best results also make sure u take off the icm and clean all the carbon off it try and make sure its quite clean for the best results and reverse the surgery to put back on also reset the ecu by disconnecting the battery for 10 mins then shall be all sweet have fun
    vp cxommordore
    Mar 2010
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    http://www.maceengineering.com.au/We...TALLATION_.pdf
    Those instructions with pics should make the job a little easier, just make sure you don't go using carby cleaner as i have been recommended in the past. It's corrosive and can make a mess of your TB and accompanying sensors. As marty20 said wd40/rp7 or just plain old metho will do the job nicely.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Holden VN SS
    Mar 2010
    why use carby cleaner when you can buy throttle body cleaner lol its on the shelf for a reason.
  1. How to remove throttle body?
    By poweredbycng in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-12-2009, 04:11 PM
  2. VS V8 throttle body onto VR V6??
    By matt089 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2009, 11:57 PM
  3. VL THROTTLE BODY help
    By VL_kid88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2006, 07:30 PM
  4. V8 throttle body
    By Cannon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2006, 05:01 AM
  5. throttle body
    By mistermeena in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 12:49 AM
