Anyone know how to go about stopping this? I try to put it in further... less. Got no where :S
Considering finding a thin nut to hold it there, but want to see if maybe there is another way to go about it. Cheers.
I used 2 large nuts to hold the switch into place with my wagon - but all you need is a new speed clip for the switch to sit into - tho not easy to get out or put in.
and 3 Dangerous non ABS VN's
Hmm... I was afraid using big nuts would place the switch too far forward and would cause there to be too much pressure from the brake pedal arm. Though if it works, then it works :P
So it is a nut worth forward past the speed clip then?
