Results 1 to 5 of 5
Thread: Vp wiper motor keeps snapping off bracket??
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Default Vp wiper motor keeps snapping off bracket??
    Hey guys. Had my wiper motor snap itself off the bracket not long, so I replaced it last week with one I got from the wreckers. I got the whole motor and bracket and everything and swapped it over. Drove it last night in the rain and it snapped again. The wipers did chatter a bit but didn't think anything of it.
    Has anyone had this before?
    Anyone know how I can fix this issue?
    Geoff
    VS l67 statesman
    Dec 2008
    I had this happen in my VP it was caused by the mounting bolts working their way loose so check if your bolts are stripped or try loctiting them in
    VP Executive R-spec
    Jan 2005
    I've had the alloy arms snap off my old VN, but not the bracket. Apparently the VS one can be used and is better?
    Aug 2005
    Mt Martha, Vic
    Is the wiring plug the same on the vs ones?
    The bolts holding the motor on were not loose at all.
    VK Calais EFi 6
    Aug 2005
    Just replaced the wiper motor and linkages in my VP after the linkages jammed and the motor kept turning and instead shattered the cast wiper motor gearbox housing. Grabbed a whole assembly from a VS commo at the wreckers, turns out the plug connecting the motor to the car's loom is different (its still 5 wires but its in a different plastic connector) so I just made up 5 little jumper cables and crimped them to the correct wires and then plugged them into the old connector from the VP which matched the connector on my VP's firewall
  1. VT wiper motor into VR
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2009, 09:58 PM
  2. Wiper Motor
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2009, 09:57 PM
  3. VH wiper motor
    By stubang in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2008, 11:45 AM
  4. Wiper Motor..
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:56 AM
  5. vc wiper motor
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 11:21 PM
