Results 1 to 3 of 3
Thread: how do i change oil filter on my vn?
    VN EXEC
    Feb 2010
    Default how do i change oil filter on my vn?
    hi guys, sorry i know this is a ridiculous rooky question but i think i need to change my oil and oil filter on my 91 VN v6 engine, its a series 2, can anyone tell me anything important i might need to know before doing it?? which make should i buy, any specific filter?
    vx gen111 wagon
    Jul 2009
    perth
    nothing wrong with the old cheap ryco filters just remember to wipe a bit of oil or vasaline around the rubber seal on the new filter before screwing it on. To get the old one off use a filter spanner or if not available stab a screwdriver through the filter (they are pretty thin metal) and twist it off.
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Run Engine at Idle for ten minutes to warm oil.
    Place catchpan under sump plug.
    Undo top engine oil cap to allow ease of oil flow through sump
    Undo sump plug remembering that the oil is hot!
    Wait for oil to drain
    Undo Oil filter ensuring the o-ring seal has come off with it
    clean sump plug and screw back into place
    place new oil on the new o-ring on the new oil filter
    screw on oil filter using hand, make sure its tight
    replenish oil
    run engine for ten minutes continuosly checking for leaks
    check engine oil again and top up if necessary
    $50 says someone has written up a better answer while i have been typing this
  1. VX Fuel Filter Change
    By grim-reefer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2008, 04:14 PM
  2. How much oil do you add after an oil and filter change?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2008, 06:30 PM
  3. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  4. How to change a fuel filter?
    By k999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2006, 10:01 PM
  5. how to change oil filter
    By Dave R in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-08-2005, 12:45 PM
