Results 1 to 7 of 7
Thread: VN SS engine deteriorating quickly
    VN SS
    Apr 2010
    Default VN SS engine deteriorating quickly
    Hi everyone my engine has been getting worse
    It first became less responsive, then slight misfire
    then it would only idle if u gave it any throttle it
    would die now it won't start, I've
    checked for error codes, changed fuel filter, checked
    spark on each cylinder, checked injector pulse, checked
    operating voltage of map/tps sensors, fuel pump is
    operating The engine sounds like it wants to start going
    to check compression and fuel pressure now.. Any help
    would be appreciated!!
    VP Executive R-spec
    Jan 2005
    One fuel pump might be spinning but those things have two pumps and you need both running 100%
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    do those things run a fuel pressure regulator?
    If so could also be dodgey.
    VN SS
    Apr 2010
    I'm borrowing a fuel gauge in the next few days if I get a reading
    between 45-55psi this would meen the pumps are working ok yea?
    Thanks for the help
    VN SS
    Apr 2010
    1992 VP vacationer
    Nov 2009
    VN Exec
    Dec 2008
    I know you said you looked at the TPS, but i'd also check it in a full-sweep, not just when it's in it's idle position(if you haven't already done so). Had a similar problem on a previous car - would idle fine, but the moment you thought about breathing on the throttle, it would stall. It would read fine when the throttle was closed, but the moment it was even a fraction off, the readings went all over the place, and the ecu would give up and move somewhere warmer for winter.
  1. VN starts but then stalls very quickly...?
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2010, 04:46 PM
  2. Getting Tyres Quickly
    By VicCop in forum General
    Last Post: 29-10-2009, 07:54 AM
  3. Need answer quickly!!
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2009, 11:46 PM
  4. Overheats Resonably Quickly...Why?
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 07:01 PM
  5. just need to know a few things quickly
    By Nobody Actually in forum The Pub
    Last Post: 10-01-2007, 02:36 PM
