Results 1 to 13 of 13
Thread: vp commodore hard starting
    vp commodore
    Apr 2010
    Default vp commodore hard starting
    hey i just baught a vp v6, it was kinda hard to start before, but i changed the plugs and i think its worse, it just cranks for a good 5 seconds and i give it some accelerator and it starts, i was thinking of changing the plugs again for better plugs, otherwise i was thinking starter motor, any advice would be appreciated, cheerz
    VN Exec
    Dec 2008
    Is it hard to start when it's cold, or after you've just been driving it? or no difference?
    Does the engine turn over while you've got the key turned?
    vp commodore
    Apr 2010
    hey mate, it does it when its hot and cold, it just cranks for ages then finally starts, also blows some smoke when it starts, smells like raw fuel, occasionally it starts first go but not often, it wont idle in park it just stalls, but once its in gear it drives really well..
    1992 VP vacationer
    Nov 2009
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    my mates does this, so if i clean injectors should be fine or??
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VN Exec
    Dec 2008
    change the fuel filter(under the rear axle - yes, i know, great place), then try some injector cleaner. if that doesn't work, pull the injectors out(doesn't take long) and get them cleaned.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check the vacuam hose on the fuel pressure regulator on the end of the fuel rail for petrol they leak out the diaphram and cause issues also the coolant sensor and its circuit inside the ecu fail and make for funny starting and general running.or as said above leaking injector but normally a leaking injector will start good first thing in the morning after sitting over night
    vp commodore
    Apr 2010
    now it has a bit of milky substance under the radiator cap, the coolant looks fine though, will try some injector cleaner and change the fuel filter, but now im more worried its done a head gasket or something???
    vp commodore
    Apr 2010
    vn_v6's Avatar
    Aug 2009
    victoria
    check transmission oil?? the internal tranny cooler in radiator might have busted
    vp commodore
    Apr 2010
    ok, i did notice some oil around the bottom of the radiator, i just flushed the coolant n changed the oil in the motor and the oil was fine, how do i check tranny oil and tranny cooler????
    vn_v6's Avatar
    Aug 2009
    victoria
    there is a dipstick near the oil one, on the drivers side closer to the firewall, and you cant check the tranny cooler as its inside the radiator, if the tranny oils milky to, DONT DRIVE IT, youl **** ur tranny
    vp commodore
    Apr 2010
    tranny oil is very clean... hmmm..
  1. Efi V8 Hard Hot Starting
    By rebirthed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 01:39 PM
  2. Hard starting when hot
    By markcorinna in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2009, 12:04 AM
  3. Yet another hard starting post
    By Indy_387 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2007, 06:40 PM
  4. vp commodore hard starting
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2006, 11:29 PM
  5. VP V6 Hard Starting
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2005, 11:36 PM
