Can anyone tell me what cars a VN T5 will bolt straight onto with little or no modification?
TIA
If it's a V8 one, it'll fit VN, VP, VR. It will also slot behind any VB-VL easy enough if the motor has the Chev bolt pattern. If you have a V6 version it's not quite so straight forward as it depends on if it's a S1 or S2 V6 one.
Reaper
I thought input shaft lengths were different between the 8's and 6's too?
My VR is a V6, the donor car is a series one VN
will bolt up fine just need the correct flywheel to suit vr 8 bolt pattern crank
Do you know where i can get one at a reasonable price? i have heard these are hard to come by. also, will the ecu and loom etc plug and play?
you can get them new easy enough about $600 over your way i think .i can get new billet one here for $450-500 so i heard the other day.vn loom will fit might be one or 2 wires at the battery plugs need swapping round but no major mods needed slap in a vr manual tune with antitheft turned off and away you go laughing
