Results 1 to 7 of 7
Thread: VN Cat Converter
    VN Berlina
    Jan 2008
    Default VN Cat Converter
    Hi All
    Have just started to notice a metallic popping/tapping sound which at first sounded like it was the muffler but now it appears it's coming from the cat.
    Any ideas how easy they are to replace yourself and where a good place in Sydney would be to get one? Have just spent almost a grand getting new water pump, new thermostat, new engine mounts, service etc and don't want to spend any more money than I should if you know what I mean.
    Aaron
    Dec 2009
    Quote Originally Posted by aajlin View Post
    Hi All
    Aaron
    It's not the sound of the metal contracting after you switch the car off is it as this is normal.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Four bolts to remove the cat, but they are prone to snapping off. Run the car for a few minutes to warm it up, then spray the bolts with WD40 or CRC or similar, wait about ten minutes, then they should come out. They can be tight. Once you get the cat out, look inside, you will see straight away if it is broken.
    The other thing that the VN/VP's are prone to is where the engine pipes meet, there is a small metal divider welded in the Y section to help merge the exhaust, this can break off and rattle in the engine pipe sounding like the cat has broken.
    I can do you a cat at $175 shipped. Straight bolt in.
    Visit my Facebook page
    VN Berlina
    Jan 2008
    Thanks mate. Actually it's not the cat making the sound but the the central exhaust section (cat back???) between the cat and the rear exhaust
    Dec 2009
    When does it make the sound? If it's after you turn the car off and get out it's probably just the muffler loosing heat and the metal contracting? How rusty does it look?, check it for any rust holes. The inside may also have rusted off and be loose it would make a rattling noise witht he engine runing if this was the case.
    If it needs a new exhaust just get a Lukey off the shelf system and put it on. I got the one that has a larger diameter pipe and larger mufflers (not the straight through type they look just like the standard ones, same path etc for the exhaust just a less restriction and it was fine and not too noisy.
    VN Berlina
    Jan 2008
    sorry about that, didn't supply enough info.
    Nah the sound is while you're driving/idling though it's not as pronounced when idling due to the lower revs me thinks.
    I've just dropped it down the local garage - fingers crossed it's not an engine issue. Thanks all for the info though!
    vr stroker v6
    Jan 2009
    townsville qld
    have a look at your rear muffler were the pipe it welded to they crack there because the mounts r to far back on them
  1. Best wma-mp3 converter
    By Philthy in forum The LAN Lounge
    Last Post: 13-05-2009, 12:47 PM
  2. Lockup converter / non lockup converter, whats the difference???
    By stealth616 in forum V8 Development and Modification
    Last Post: 07-02-2009, 06:29 PM
  3. cat converter
    By adamandtanya in forum General Discussion
    Last Post: 04-09-2008, 06:06 PM
  4. cat converter
    By patrix in forum General
    Last Post: 31-10-2005, 07:26 PM
  5. cat converter
    By patrix in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-10-2005, 10:24 PM
