My VNs drivers door wont lock anymore.. To lock the car I need to unlock the back right door, get out, shut the drivers door and lean in through the back to lock the front door, then lock and close the back door from the inside too.
The drivers door unlocks with the key, but won't lock. Any ideas on what I'm up for / easy fix?
I'm just gonna do this:
replacing vn door locks need help
Get a new lock.. It's already a different key so it won't be any worse
ksickdone
Just make sure the orange plastic insert on the snib is not falling out and catching when you try and Lock. Worth a look as it a simple fix other wise as above post recommends
Dazz
VN BT1 Mock Up Commodore
Dynamic Locksmiths
Will do, didn't drive to work today but I'll check tonight. Thanks heaps mate
