Results 1 to 3 of 3
Thread: cleaning the cas
    vp cxommordore
    Mar 2010
    Default cleaning the cas
    her i was wondering if the cas on a vp had any kinda connections to clean cause my car will not start and ive cleaned all the coil the sparkplugs spark leads and fuel enjectors and it still will not start im pretty sure its the cas because when it use to start it would ony run when it was cold when it got hot it wouldnt start until it cooled down
    VS Commodore Series II V6
    Apr 2010
    You may just need to replace the whole CAS.. do you know where it is.. its behind the big pulley on a VS..the hard bit is removing the pulley..
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Repair by replacement. You'll need to remove the harmonic balancer (big pulley at the bottom there) to get at it.
    WTB: mulberry VN interior parts
  1. MAF cleaning?
    By tomholzy in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-01-2010, 02:32 PM
  2. Cleaning MAF
    By pk2k78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-06-2009, 06:52 PM
  3. cleaning your car
    By Troy711 in forum The Pub
    Last Post: 11-12-2007, 11:36 AM
  4. Cleaning you car - What do you use?
    By Indy_387 in forum General
    Last Post: 25-07-2005, 03:23 PM
  5. Car Cleaning
    By Troy711 in forum General
    Last Post: 23-01-2004, 12:08 AM
