hey guys, ive had a few mechanics tell me that my speedo transducer sensor thing is leaking, how do you fix this? should i get hold of a brand new sensor? or is it just replacing an o-ring? any ideas would be muchly appreciated
Yep, there's an 'O' ring in the hole in the trans. extension housing which goes hard with age and leaks - replacement only requires removing the 10mm head bolt and the clamp.
There is also a sealing washer inside the speed sensor - VS19145.
Occasionally the sensor housing itself will crack and leak.
