Results 1 to 7 of 7
Thread: V6 manual flywheel bolt torque settings?
    1992 VP vacationer
    Nov 2009
    Question V6 manual flywheel bolt torque settings?
    I know I know do a search. Well I didn't find the info I needed. Not even on google.
    Anyway can some one with a work shop manual tell me what the torque is on both the manual v6 flywheel bolts and also the pressure plate bolts .
    Cheers.
    P.S. someone guess now much the flywheel bolts cost?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    my VN manual says 90Nm. figure it must be the same for the VP. if you purchased the new bolts from Holden you probably got ripped
    Body by Holden, Soul by Brock
    the Legend will live forever
    1992 VP vacationer
    Nov 2009
    yeah sure did. looked every where and couldn't get after market. sign most expensive part for its size and weight on the whole car. 57 buks
    1992 VP vacationer
    Nov 2009
    that got be series one you talking about there. holy crap 90nm is like 67 ft lb yeah that more than head bolts on a ford. they are only 8mm tiny little things.
    Apr 2006
    Auckland NZ
    the flywheel bolts are torque to yield. which means they are a one time use bolt. what happens is it is torqued up to the point where the bolt is stretched beyond it's elastic ability (will return to it's original length when removed) into what they refer to as plastic deformation. i.e. when the bolt is removed it stays deformed (stretched).
    i purchased ARP bolts for mine which are re-usable and only cost me NZ$16 for 6. although it helps that my flywheel bolts are the same as the chev 350 flywheel bolts
    1992 VP vacationer
    Nov 2009
    yeah that would help. mine are these weird looking small things. lol the bolts holding shifter on the box are bigger
    VY Calais Supercharged
    Sep 2008
    Auckland, New Zealand
    Just went through the same thing today for my VP. Flywheel bolts from Holden were $13 each x 8, OUCH. When I went to pick them up they were just grade 8, 5/16 unc with a bit of loctite splashed on them. Off to buy some tomorrow for about a dollar each!!!!!
    Dunno if the Holden ones were torque to yield or not, certainly didn't look like a TTY bolt.
  1. VN-VS 8 Bolt manual t5 flywheel
    By hillboy89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2010, 05:30 PM
  2. banjo bolt torque settings
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2009, 08:08 PM
  3. Rocker arm pivot bolt torque settings?
    By riss666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2009, 06:16 PM
  4. Head Bolt Torque Settings for VT Berlina
    By Missy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2008, 05:51 PM
  5. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
