Results 1 to 10 of 10
Thread: ratteling noise when driving
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Unhappy ratteling noise when driving
    hey all
    i have this ratteling noise coming from the engine bay when i drive, its only wen im goin really slow and havent got much pressure on the accelerater you can hear it wen ur in the car and wen i drive past some1 it annoys me and it make my car sound like a bomb witch it isnt please help
    cheers
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Most times it's the Engine Mount(s) have slight collapsed..Enuf to touch on the Exhaust Manifolds.
    I belive..The way to check them is, See if the Rubber on the Mounts are cracked etc ?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    typical vn most likely the timing chain tensioner has torn off and is in the sump the sound is the chain slapping round
    Jan 2010
    the noise seems 2 b coming from the back of the engine :S iv got no idea wtf is goin on but it shits me
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Engine has collapsed slightly, and is touching the Exhaust Manifold.
    Check your Engine Mounts...If the rubber is all cracked..or gone, I believe it needs replacing.
    90 vn wagz and 90 vn sedan
    Feb 2010
    My friend picked up a rattling noise when i had my foot slightly on the accelorator yesterday. I will check the mounts on Monday.
    Vp calais, gemini
    Feb 2008
    melb, vic
    cat converter can hit the bottom of the car (near passenger foot well) if your engine mounts are shot, but like most vn's your probly hearing a timing chain rattle, mine used to do it loudest going up a hill quarter-half gas pedal.
    vn v6 calais mock up run around,
    vn v6 manual wagon parts car,
    vp v6 berlina lx project car
    vc 186 aussie 4 speed
    vl 6cld wagon
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    same thing happened to me mate, it was 2 of my back brakes so pin/clip thing was pretty gone the mechanic said lucky i got it checked when i did (its been doing since i had it 2 yrs lol) cus my brakes were pretty much failing at the back
    so id go get it checked by a good mechanic mate
    Also when i put pressure on my brakes the noise went away cus something locked in does ur do this? then when i took it off the clip ratteled again
    good luck mate
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Feb 2010
    Actually speaking of back brakes (my left hand back wheel) i have no clue whats going on, at first i thought it was the wheel brace, but now it seems to grind if i take off with a fair amount of force on the accelorator. Also grinds if i go to take off turn left with a bit of wheel spinning. It all started when i skated it around a corner, chucked on the brakes for a speed bump (which i hit at the recommended 20kph) and its played up since. Ever since then i go over bumps 5kph lol. But that engine noise is also coming from the passenger side i think. Its where my friend was standing when i started the car and slowly went down the street.
    Jan 2010
    sweet as ill check my mounts hopefully thats the prob i dont c how it could b the timing chain wen they r usually at the front of the engine or in my cars case its on the side wen looking from front of car ( the old s1 engines where they r a front wheel drive engine lol) i had a good listen 2 it the other day and it seems 2 b coming from fight down the back of the engine so maby it is the mounts
  1. Squeal noise when driving
    By Callumm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2010, 03:56 PM
  2. front end ratteling
    By vh ~ very horny in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-05-2007, 10:38 PM
  3. Ratteling
    By kim_08 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 01:54 PM
  4. Ratteling Sound
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2005, 02:16 PM
  5. Rear driving noise
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2005, 11:37 AM
