Results 1 to 7 of 7
Thread: changing vp front springs to lower 1s how to ????
    1993 yota 4 runner sr5. Sadly sold vp s
    Oct 2009
    sa
    Default changing vp front springs to lower 1s how to ????
    ok guys i wanna change my front springs on my vp, is it hard to do and if so can you give a run through on it
    how low springs should i go on the front ?????
    cheers if you can help
    im more just wantin to save money and seeing if i can do it myself thanks
    Oct 2009
    sa
    ok b4 some1 says somethin about the search bar and yes i have looked and yes i have found the how to thread. but i cant see any of the pics i dnt know what is wrong
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You need spring compressors, a massive vice, and a rattle gun. Without those, don't even contemplate it You'll hear people talk about all sorts of other shortcuts you can take, but half the time they won't work.
    The 1972 HQ Kingswood
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I didnt use a rattle gun, you just need to stand on the strut in just the right place
    Whats the massive vice for?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Vp ss commodore
    Aug 2009
    vp 6c turbo ute
    May 2010
    massive vice??? huhhh! take out the strut get a rattle gun undo the top nut and run haha. no the old spring will be worn and not to much froce to it {or just cut it in there with a grinder=easy} and if u have spring compressor it will make it easyer if not there like 20 buks from supa cheap or somthing. the new lower spring will be alot shorter than standed but stiffer so if u can push it down far enough to start the top nut then ur rite, then just do it up with the rattle gun. make sure tho when ur puting the strut back in that the 3 bolt ends go back in the same way or when they do wheely on it, it will be more than just way out. not to bad i was a wheel aliner for 5 years thats how we did in, when in a hurry anyways.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by mitchhsj View Post
    ^I duno, I got caught out like this.. didn't compress a stock spring before pulling the strut open and I almost shotgunned my eyes out with those little ball bearings. Collecting 40-odd bearings from all around the shed where they ricocheted was not altogether fun..
    WTB: mulberry VN interior parts
  1. changing front struts/springs
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2009, 11:05 AM
  2. changing VZ front springs?
    By Troyziee in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-12-2008, 12:11 PM
  3. changing front springs
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2008, 06:57 AM
  4. changing front springs in vn
    By Gav86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2007, 01:57 PM
  5. Changing Front Springs
    By rian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2007, 04:31 PM
