when i have air con on for a long time, if i turn left all this water splashed into drivers foot well, its good when its reallllly hot outside, refreshing hahaha, but im sik of smelly carpet, any idea people?
sounds like the drain off the evaporator may be clogged or not connected properly.
stick your head up there and have a look around with a torch see if you can trace it.
My brother in laws was leaking, but was an easy fix. (hose was just deteriorated...)
The little 'bleeper' valves dry shut. I cut mine off so they will never block again.
the tube that drains the water out of the air con is blocked by the sounds of it
Happened in my VN too. The drain outlet is above the transmission. I unblocked it by shoving a length of welding rod up the drain tube. Bit hard to get to with the car on the ground though.
Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
