Results 1 to 5 of 5
Thread: Oil leak out the top of the pressure sensor...
    VT Calais 3.8
    Nov 2008
    Default Oil leak out the top of the pressure sensor...
    Hey Guys,
    I've got a pretty bad oil leak coming out of the top of the oil pressure sensor where the plastic and the metal meet, on my VP Lexcen.
    When i say pretty bad i mean horrible, it pretty much just flows out there. Would this be the sensor itself? i read there's a pressure relief valve there somewhere and thaught it may be kicking in due to a blockage or something.... not sure.
    So two questions really, is that where the pressure is released from? And if not does that mean the sensor is gone?
    I need to figure this out soon because i pretty much have to walk or catch a CAB to wherever i need to to get to get the shit i need to fix this.
    Cheers,
    Voney
    1992 VP vacationer
    Nov 2009
    yeah change that sensor. Mine did the same thing and lucky I put more oil in as I nearly ran the sump dry. they are 23 buks from burson's
    VT Calais 3.8
    Nov 2008
    Yeah, i just finished changing it now. As well as the filter.
    Looks to be OK, got the sensor from REPCO for $16 not bad.
    Now my car is its normal level of crapness instead of ultra-crap. :P
    1992 VP vacationer
    Nov 2009
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Just note in future, it's always worth using a torque wrench when doing up those sensors. They're slightly tapered, and if you screw them in too far it's possible to split the housing on your oil pump. Not so much for you, but for anyone else that looks up this thread
    The 1972 HQ Kingswood
  1. High Pressure Power Steering Leak
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2009, 05:22 PM
  2. oil pressure sensor
    By shane100 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-03-2009, 06:25 PM
  3. oil pressure sensor
    By Deathadder in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-08-2008, 08:59 PM
  4. Oil pressure sensor
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 11:48 PM
  5. Oil Pressure Switch leak
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 01:57 PM
