Results 1 to 4 of 4
Thread: Error Code Help (Code14?)
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Error Code Help (Code14?)
    Hi Guys,
    Need your combined wisdom again.
    My engine warning lights on when driving and I did the ECU check thing with the paper clip and it returns what i think is code14?
    I recorded it as im not sure because of the pause in between its either C12 or C14
    Code 14 - Coolant temperature Sensor - Voltage Too Low
    If its C14 any ideas on a fix? replace the temp sensor?
    The sensors probably been in there since factory and its currently at 356,000km.
    Heres the video
    YouTube - MOV00004
    Flashes once, 1 sec pause then 2 flashes .5 second pause 2 flashes.
    Thanks
    VN Executive
    Apr 2007
    Yesterday it stalled about 3 times when i was trying to do a U turn. Its an Auto
    Just revved it up cold to about 3k and it seemed to have a miss between 1500 - 2700ish RPM.
    Started fine and the engine light goes out randomly then comes back when you turn or go up a hill (could be a coincidence)
    92 VP Series 2
    Jan 2009
    East Brisbane
    hey mate, to me that looks like a code 22 (TPS sensor). i've had this code a few times. have you recently done anything with your throttle body or the sensor that sits below the butterfly of the throttle body? i would suggest to replace the tps sensor and make sure the electric connector wiring that connects to the tps is clean and not full of gunk and shit. good luck mate
    VN Executive
    Apr 2007
    Cool thanks for that. About a month ago I flushed the cooling system and had to remove the throttle body.
    Ill have a play around with it on the weekend.
    More comments welcome.
  1. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  2. o2 Error code 13 on S2 V6 VN
    By Chirpstr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2010, 11:12 PM
  3. Error Code 42, help me please...
    By Changa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2009, 01:07 PM
  4. Error Code 75
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 02:40 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
