I recently cut my springs in the VG ute and it made the suspension really hard....I had a look under the car and saw that the rubber stoppers were about 2cm away from actual stopper.. is this the reason why...and if i was to put super low springs in would i still have the same problem
Cut springs, there is your first problem. Putting lowered springs will harden your ride, it's supposed to with most lowered springs. Remove the cut springs as soon as possible and install some proper lowered springs and shortened shock absorbers. You're probably riding on your bumpstops and hence it feels very hard.
Cut springs are hugely more likely to bottom out, which is probably why you have such a crap ride. Aftermarket springs will tend to be thicker to prevent this. Cut springs = fail.
ahhk cheers..im planning on gettin some new springs within the week
very good idea
VN BT1 Mock Up Commodore
Dynamic Locksmiths
does anybody know wheather the VG ute has IRS or the other suspension setup watever its called
no irs mate. its live axle.
yea live axle. i to have a vg with 19s i cut the bump stops off the body and diff witch gives bot 4'' more space with king springs SSL and cut one cole off top and bottom, and a bit of bashing with a hammer in the guard and it tucks real nice and rides good too, but i put my stand up jetski in the back {140kgs} and my shoks start bottom out> oh well
got new springs finnaly...they in the back couldnt be bothered doin the front yet made a noticeble difference, still might do wat mitch did and take out the stoppers as they are still really close
Hey guys doesn't cutting the bump stops make your car defective ?
yes! I am pretty sure it does. I am sure you can buy shorter ones anyway.
Nolathane make shortened ones i think, if not it was whiteline.
The Daily VN T5V6
355 VN GRP A REP
Are they expensive and hard to fit ?
i dont think they cost any more then $100 for a set but the hard thing u will find is getting them off without burring the nuts. i burred the nuts so i just cut the stopper instead.
