Results 1 to 7 of 7
Thread: VP No injector pulse
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default VP No injector pulse
    My mates vp has no injector pulse havent looked at it yet but will be shortly
    what do you think it might be
    Morton's Avatar
    Fairstar the Funship
    May 2006
    What sort of engine is in there, an SR20? Perhaps a 2JZ-GE? Or maybe a V6 or a V8?
    The 1972 HQ Kingswood
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    VN Executive
    Apr 2007
    Wellington, New Zealand
    My mate had an engine out of a Levin GTZ (4-AGZE) which had a similar problem.
    We suspected the ECU but turns out it was something else to do with the wiring or something. Never found out as he sold the car before getting it going.
    VS Exec 5spd
    Aug 2008
    can be a fault within the ecu itself or else just a fault in the wiring somewhere between the ecu and injectors
    VP Exec
    Jun 2005
    If the injector pulse is the only thing missing i.e. there is spark and there's not a "check engine" light with the ignition on "reds", it's probably a fault in the anti-theft system/BCM. Most often it's the switch in the passenger side 'A' pillar. If you have the key, try turning the switch to "off". If no key, unplug and bypass/jumper wire the switch terminals (=> drill out a rivet or two to remove the plate shielding the wiring connector behind the vent).
    If bypassing the switch "off" yields an injector pulse/CEL and the switch is OK, the BCM or remote is probably faulty (although it might be the wiring to/from the BCM and the ECM). The BCM and (a) matching remote(s) can be replaced. The BCM is above the vent dusct behind/above the glovebox.
  1. No Injector Pulse VS ECOTEC
    By Tomwally in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2011, 07:01 AM
  2. Vs V8 Berlina No Injector Pulse
    By TEMPA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2010, 12:25 PM
  3. Puzzling injector pulse problem
    By Psycho R8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2010, 08:33 PM
  4. No injector pulse car wont start
    By VS5LT in forum Electrical Wiring / Questions
    Last Post: 23-09-2008, 04:41 PM
  5. no signal pulse at injector
    By jimrichards1964 in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 07:56 PM
