Results 1 to 2 of 2
Thread: Vg knock sensor problem
    VG S 1 UTE
    May 2010
    Default Vg knock sensor problem
    hey Guys , just bought a vg ute with series 1 vn motor/borgwarner 5 speed have noticed the engine management light is on, did the paperclip trick and got fault code 43 which i believe to be knock sensor problem the knock sensor wire seems to be nonexistent so where should the plug come from? does it go to the fuse box on rh inner gaurd? or the ecu wiring harness?
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    The knock sensor wire (there's only one wire) come from the loom which runs under the above the oil pump. From there it goes to the ECU.
    I once had the code 43 problem and turned out to be faulty knock sensor.
  1. Vr Knock Sensor
    By gelousi in forum Electrical Wiring / Questions
    Last Post: 17-02-2010, 11:14 AM
  2. knock sensor
    By viccib in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2009, 10:57 AM
  3. Knock sensor
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2006, 06:50 PM
  4. knock sensor
    By Garth in forum Swap / Wanted to Buy / Trade
    Last Post: 07-02-2006, 03:22 PM
  5. WTB: VR knock sensor
    By 2_SeeK_U in forum Swap / Wanted to Buy / Trade
    Last Post: 13-12-2005, 12:25 PM
