Results 1 to 6 of 6
Thread: coolant dripping from sump?
    VS executive
    Jun 2009
    Default coolant dripping from sump?
    just noticed at the servo a few drips of coolant under the car so i had a look and its dripping from the drivers side front of the sump , any ideas where the leak may be?
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, second that. Look directly below the pulley on the pump to see if there is any coolant there.
    Visit my Facebook page
    VS Exec 5spd
    Aug 2008
    thermostat housing leak could also run down to that point and drip off the sump.
    VS executive
    Jun 2009
    you mean the thermostat that goes into the block near the pulleys? i had a new one put in about 8 months ago , ill check the water pump
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    if its like that, its your waterpump
    The Black Beauty
LinkBacks (?)
  1. VS v6 coolant dripping from trans...
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2010, 03:21 AM
  2. Air Con Water Dripping?
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2010, 04:47 PM
  3. Orange Fluid Dripping on to Sump?
    By mattsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-12-2009, 07:43 PM
  4. Coolant in sump - No Oil Pressure - WTF??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 12:45 PM
  5. dripping
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 05:37 PM
