Results 1 to 4 of 4
Thread: VN problem, car shutdown at lights and wont start again
    VL berlina
    Dec 2009
    Default VN problem, car shutdown at lights and wont start again
    hey guys, last wednesday my vn just shut down (its auto) on idle at the lights.... it started again momentarily for 2 seconds or so but that was it...the past two days before that on idle there would be a loud vibration comming from either the engine bay or under the car but i couldnt see a problem but for some reason i dont think its related but just everything has happened in the past week. its now at the mechanics but maybe you may know what the problem is....
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Does your "Check Engine Light" appear?
    When it's working.. Does the car feel sluggish?
    Does it over-heat much?
    Is it chewing it's fuel badly?
    The Vibration may be your Exhaust Manifold.. Or, your engine mounts have sagged enuff to touch the Zorst mounts..
    If the Zorst manifold is damaged it's possible that can be your cause for Engine Stalling
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    engine shaking may be to do with the electrical side of the engine. Coils, leads, plugs, CAS and ECU all play a part. Any start to fail the engine developes a missfire.
    and 3 Dangerous non ABS VN's
    VL berlina
    Dec 2009
    the engine light appears, so does the oil light. it overheats because it drinks water.....head almost gone, it does drink aswell alot
  1. statesman 5l wont start!! ecu maybe a problem??? need help asap!!!
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 07:20 PM
  2. VT cranks but wont start (problem solved!)
    By xCalliba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2010, 10:25 PM
  3. fanbelt snapped replaced it now car wont start what could be the problem
    By vn_sleeper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2009, 02:15 PM
  4. Ignition problem, Key wont start car.
    By tattoowrx in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-02-2009, 06:58 PM
  5. Problem -S/Charged V6 Cold Start wont idle
    By colgf in forum General Discussion
    Last Post: 06-09-2007, 05:47 PM
