guys need help will a v6 transmission fit in a v8??
no different size bell housing
auto or manual? ....... no or maybe (with mods)
Body by Holden, Soul by Brock
the Legend will live forever
the auto is the same internally almost but the bellhousing is diffrent so with an auto no cause they are a 1 peice case as for manual yes but with a fairly large amount of modification as bellhousing is diffrent and so is the input shaft so if i was u stick to using a V8 box behind a V8
Just use the existing bellhousing on the v6 box
v6 and v8 bellhousing are DIFFERENT
Its not that hard to change to a V6 manual box if you had a V8 manual box in there to begin with. Just change the bell housing and input shaft, you will also have slightly lower ratio gears in the V6 box so speedo will be out but it will give you a bit more acceleration.
If ive of had a V6 T5 handy at the time i would of swaped it with the V8 one.
The Daily VN T5V6
355 VN GRP A REP
I actually meant the automatic, but then I went back over the thread and saw that you said autos were one piece
