Results 1 to 7 of 7
Thread: Wanting to do up a low km buick v6!
    VNAer0HDT's Avatar
    VNAer0HDT is offline Bricky - We lay You pay
    VN Berlina
    Aug 2009
    SA, Adelaide
    Default Wanting to do up a low km buick v6!
    just wonderin what are some of the basic and high priced mods out there to get some kick out of a v6.
    cause i want to keep my car as my daily but still be good. while i buy my silvia s13 as ma track car.
    ive searched for a few things including-
    Extractors
    2.5in exhaust W/ twin tip
    70mm Throttle Body (Bored & Polished)
    Stage 2 Shift Kit
    LSD Diff W/ 3.9 Gears
    Can i buy a CAI enclosure and also attach a CAI system to it.. or is it 1 or the other and if so whats mroe of an increase?
    Vn Berlina
    Jul 2009
    Ballan
    1992 VP vacationer
    Nov 2009
    nah dont bother with injectors. stock ones are rated at 36bhp each x by 6 = 216bhp.
    you can add high ratio rockers to your list. that will be the bigger single increase mod out of all the others you have there.
    Oh you will need a tune to calibrate the ecu to all your mods to make it actually work decent.
    VN S Manual
    Jul 2009
    SC14 charger? can usally get kitted up for a grand. If you run small boost, you can still get a considerable increrase without having to intercool and upgrade your injectors.
    VNAer0HDT's Avatar
    VN Berlina
    Aug 2009
    SA, Adelaide
    were could i find a SC14 Kit and what intercooler and injectors would u reccomend for it?
    would i need other stuff in my engine to make it run nicely?
    VNAer0HDT's Avatar
    VN Berlina
    Aug 2009
    SA, Adelaide
    what power would i expect out of -
    70mm Throttle Body
    2.5in Catback Exhaust System
    Pacemaker Extractors
    1.9:1 High Ratio Rocker Arms
    Cold Air Intake System
    Tuned
    Whats some major increases i can get out of a V6 buick without having to engineer a SC or Turbo.
    VN S Manual
    Jul 2009
    You will have to do a bit of searching aorund the forum to find accurate information as im not sure. I know that you can run low boost. and still get a considerable gain, then later on change to a smaller pulley which will up the boost. when doing this you should have bigger injectors (exact size im not sure) and intercooler, depending on how much extra your going you should have some internal mods done, as theres alot more pressure being put on the internals.
    I only know a little, looked into a while back. If you do a bit of searching you will find what you need, or better yet talk to somebody who has done it.
  1. vs dies wanting to put buick 3800 in
    By sawychri06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2010, 03:20 PM
  2. wanting a VE V8
    By vlpwr in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-10-2009, 07:19 PM
  3. [SA] wanting a V8 whole car
    By SAV_117 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-02-2009, 12:43 PM
  4. wanting to get a SV6
    By nathsvrbt1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-01-2006, 10:46 PM
