Results 1 to 2 of 2
Thread: Coil testing
    Jul 2008
    Default Coil testing
    This is quoted from another thread.
    " Ok fellas, to test your coil packs,
    With the engine off, take the first 2 leads of the first coil pack and then start the engine, now have a look @ the metal tips on the coil pack, the spark should be jumping from tip to tip, if the spark jumps anywhere else then the coil is stuff/on its way out! If the coil is ok then turn engine off, replace leads and move onto coil pack num2 and so forth on number 3! "
    Would any one be able to tell me how and why this works ?
    I had a coil that showed ok on the multimeter, But when i performed this test it arced out through the plastic caseing once every 2 or 3 seconds or so.
    I replaced that coil and all my problems went away.
    Jul 2008
    Any ideas ?
  1. Vs commodore coil pack testing?
    By binny in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2010, 02:15 PM
  2. Testing LS1 Coil pack
    By G4orce in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-12-2009, 10:35 PM
  3. Testing the coil on 5l VS/VQ
    By Meerkat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 12:45 PM
  4. Testing Coil
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 07:00 PM
  5. Coil Pack Testing
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 08:10 PM
