Hey guys can you help with problem my son just pick up his vn v8 but now it will idle rough and not rev up at all then stalls but switch to gas it runs fine any ideas. fuel tank gauge shows half but i think it just could be very low on fuel.?
put more fuel in first see if it helps, maybe change fuel filter if its been mainly used on gas, fuel filter could be blocked. if still no good, maybe get injectors cleaned out.
will give that a go thanks for that
Hey we tried fuel and bingo it fix it what we found out the gauge show higher than tank level need to adjust fuel gauge. thanks for your help all works fine.
michael.
